(Topic ID: 104381)
Road Show buyer's checklist
By huntpinball
7 years ago
  • 10 posts
  • 4 Pinsiders participating
  • Latest reply 7 years ago by huntpinball
#1 7 years ago
What are the things to look out for when buying a Road Show? And how can a novice check for them? Thanks
#2 7 years ago
1. Crack ramps where the ball enters on either side, not much you can do as most are.
2. Working heads, check in test for mouths, eyes up and down and left and right.
3. All head outer plastic sections are there, and not broken – you cannot buy. Same with eyes.
4. Fish wear from out of the scoop.
5. Broken post in the blast zone (repair you can buy for this).
6. Working eddy switches, if either mouth is not working, try adjusting under PF.
7. Broken plastics – other than slings, which are hard enough to find, the rest are impossible.
#3 7 years ago
Great game, eddy switches are the big thing that goes out on RS. It's a pain every time you turn on the game and you have to make an adjustment. They do make replacement ones and it's well worth it.
#4 7 years ago
Quoted from Kingpin22:
I have replaced both trimmers on eddy boards on mine (about $1.5 in parts) and they are ok since I have done it (3 years, 3000+ games after).
#5 7 years ago
Quoted from Atomicboy:
8. Look at the apron - many Road show machines have paint flaking because of the rust underneath.
9. Shaker motor - is it working/not working or maybe the complete assembly is missing.
#6 7 years ago
Quoted from rygar:
Where did you find the trimmers? I worked with ED from GPE on this for a while, but the only replacement I could find was not tight enough and fell out of alignment frequently.
#7 7 years ago
An ex op recommended them to me, I ve got them in the local electronics shop. I am attaching a picture of them. Let me know if you cannot find them and I ll send you a pair.
#8 7 years ago
Ha! I ve read the marks on them myself and here is the manufacturer : http://www.acptechnologies.com/
#9 7 years ago
Op did a neat trick on his RS when replacing the trimmer. He super glued it to stay in the working position and it never failed again on a location. I did not do it on mine for home use.
Post edited by rygar: additional info
#10 7 years ago
Thank you all for the quick response. I will update when I get eyes on the game
