Hey guys looking for some help for some trouble that I'm having with my Roadshow. I have taken out the daughter board that holds the batteries due to some concerns about possible leakage. I have installed an nvram chip and socket.
I had it professionally installed and he did a very good job so I'm not concerned about any lifted traces. He did it with me present and removed the existing chip installed the new socket in probably 10 minutes And didn't have the heat on very long.
Anyway I got back home reinstalled the board and connected all the connectors and when I turn on the game the screen was blank there was one tone and nothing else happened. On the LEDs on that main board d-19 was on solid D21 was on solid and D20 doesn't come on at all. I then tried to shut it off and reseat all the connectors. When I did that the display came on but was quite garbled up and not readable. However when that happened d-19 LED shuts off and just D21 stays on solid.
I have tried reseating the chip I have also tried putting the original chip in that socket and I've reseated the connectors several times. After trying this several times, reseating the connectors my display has disappeared again and now I'm back to d-19 and D21 on solid.
It doesn't look as though I'm able to get it to boot to the point where the D20 LED can give me any indication as to what I may have done. Any help you could give me would be great thanks.
