I have stripped down a filthy Road Kings I recently picked up to remove mylar and clean up. Got the mylar and glue off, then cleaned it up with magic eraser/isopropanol and novus 2, its looking pretty nice.
Want some advice on some inserts that are sticking up a little on one end. a few of the arrow inserts are sticking up at the point, I'll post a picture. What is the best way to fix this? lay down a piece of wood and gently tap them down with a hammer?
also some paint wear around the edges of some of the inserts, I've heard of people filling it in with a black sharpie marker is that a suitable fix?
Finally should I put new mylars around the pop bumpers or leave it bare? somebody had cut off peeling mylar around the pop bumpers with a knife and cut the paint also. Will this just flake badly if left alone, or will a few good coats of wax protect it decently. Dont know if I want to go as far as paint matching and touching it up, I dont need it to be perfect, just want to clean it up as much as possible. I'm not going to clearcoat the pf, but should I put a little clearcoat in this spot?
