Hi pinball friends!
Im going to try and describe the situation…
I have an issue with my Road Kings that just happened recently.
While playing my bottom pop bumper locked on and fried the transistor that is tied to that pop on the cpu board, killed the coil, and blew the fuse.
-The coil/sleeve was replaced
-the leaf switches/spoon were adjusted
-fuse replaced
-transistor q79 replaced
After starting a game the pop is fine, once it gets engaged it stays locked on.
After a power cycle it remains locked on and even when the machine is off.
The coil, coil diode, transistor have all been checked via tester and are fine.
Im thinking that it may be a chip issue on the cpu board, but didnt know if anyone else has had a similar issue?
What should i try to do next?
