Help - I'm no expert
My left flippers plunger link broke during game play which for some reason took out the 5amp fuse on the flipper board in the top/back box. Replaced the fuse and Im now getting 73v back to the flippers. The left flipper now works BUT the right flipper is flipping me two fingers
When you push the right flipper button the flipper moves slightly. Probably about 1cm and very slowly. I have done a resistance test and get about 80ohms on the outer pins and about 2,5ohms between center and outer which I think is good. I have linked/touched an earth jumper to the centre pin and WHACK - it works fine... so I don't believe it's the coil.
Help....?
Gary
