(Topic ID: 326659)
Road Kings flashers
By rrss
4 months ago
  • 3 posts
  • 2 Pinsiders participating
  • Latest reply 3 months ago by rrss
#1 4 months ago
It seems like I've been cursed with locked on coils and flashers this week. My Road Kings has all four #63 incandescent flashers in the backbox locked on as soon as I power up the game. I replaced the TIP102 at Q14 and the corresponding 2N4401 predriver at Q10, no difference. I sorta figured it wasn't a transistor issue since Q14 is shared with the drop target reset coil and that still works as it should. The snubber relay board still appears to work because when the drop target coil resets, the flashers go out for a second, which I believe means the relay successfully moved the Q14 circuit over to the coil, then back to flashers. I replaced the diodes on the snubber board just for good measure, but made no difference.
I also tested the resistors on the resistor board for these flashers, they are still good. What am I missing?
#2 3 months ago
If the drop target reset works correctly, then you know all the circuitry up to the multiplexing relay is good. You also know that the multiplexing relay works, so that leaves you with the flasher circuits themselves. You said that you have already verified the warming resistor values which would lead me to suspect that the incorrect flasher bulbs are installed. Have you checked that the flasher bulbs are actually #63 incandescent bulbs?
#3 3 months ago
Yes, I put new #63 incandescents in all the flashers when I was shopping it a couple weeks ago. I went further back in the circuit on the MPU and replaced the 7408 that's upstream from the transistor, that seems to have fixed it.
Gweem's Mods
Sound/Speakers
$ 27.95
$ 54.99
Shooter rods
$ 12.00
$ 18.95
$ 54.99
Shooter rods
$ 29.99
$ 52.99
Pinball Shark
Shooter rods
Men
$ 22.50
Magazines/books
Pinball Magazine
Magazines/books
$ 19.99
This page was printed from https://pinside.com/pinball/forum/topic/road-kings-flashers and we tried optimising it for printing. Some page elements may have been deliberately hidden.
