(Topic ID: 247824)
Road Kings- Batteries Warming after Remote Battery Pack
By pindude80
  • 5 posts
  • 4 Pinsiders participating
  • Latest reply 4 years ago by pindude80
#1 4 years ago
Last night I went to install a remote battery pack that I got off of my friend. It's a 4 battery pack that holds 3 and has a diode in the 4th battery spot. I hooked it up and after a few minutes I noticed the batteries were getting warm. All of the positives face down on the board so I installed the dowel for the positive going down and the negative going up which should be right.
Is there an issue installing remote battery packs on system 11 games or something I might have done wrong?
#2 4 years ago
You probably have something wrong. As seen in the pic below, make sure the positive lead (usually green or red) is on the lower left, negative lead (usually black) is on the upper right. Check the wiring of the pack, make sure it is series wired, and check the battery orientation required in the holder, as sometimes these are different than the orientation of the games original holder.
The diode in the holder is not needed. The game already has a blocking diode on the motherboard, test and make sure it is good. I recommend cutting the diode on the external pack out and replacement with a jumper wire.
Screenshot_20190722-165818 (resized).pngScreenshot_20190722-165818 (resized).png
#3 4 years ago
The diode on the board may be bad, allowing the 5 Volt supply voltage to charge the batteries.
#4 4 years ago
Post a picture of your battery pack.
#5 4 years ago
Thanks for the replies. I had it hooked up as Wayout's picture. Last night I didn't touch anything and put the batteries back in the battery pack, I left the game on for a couple hours and the batteries never even got the slightest bit warm. I'm guessing the night before when I had it hooked up wrong the batteries got warm, I tried the orientation as Wayout posted and the batteries were probably still warm from when it was hooked up incorrectly.
$ 18.95
$ 27.95
$ 29.99
$ 12.50
RoyGBev Pinball
$ 54.99
$ 95.00
Pinball Mod Co.
$ 18.00
$ 19.99
$ 22.50
Great pinball charity
Pinball Edu
