(Topic ID: 119908)
Riveting targets, a new tool.
By way2wyrd
9 years ago
  • 17 posts
  • 13 Pinsiders participating
  • Latest reply 6 years ago by dasvis
  • Topic is favorited by 12 Pinsiders
    #1 9 years ago
    So there are a ton of threads on what tool to use to rivet targets and how expensive they are etc.
    I decided to try something new. After doing some research on rivet size on the Leather forums and such I bought an 1900s Rex #27 Leather riveter off ebay for 10$.
    Works like a charm. This is a good alternative to hand tools and expensive presses
    Here are some pics. I taped over the face and rivet head to make sure they were not damaged.
    --Jeff
    WP_20150228_20_16_19_Pro.jpgWP_20150228_20_16_19_Pro.jpg WP_20150228_20_16_28_Pro.jpgWP_20150228_20_16_28_Pro.jpg
    #2 9 years ago
    Cool! Very similar to the press kits available, but a lot cheaper.
    #3 9 years ago
    Does it look like this press will be able to handle riveting things like mounting brackets to metal ball guides, flasher bulb sockets to plastics, etc.?
    #4 9 years ago
    Quoted from jibmums:
    Its a press. I dont see any reason why it wouldnt
    --Jeff
    #5 9 years ago
    Great Item at a Great Price!
    Nice going on the research Jeff.
    Ken
    #6 9 years ago
    Good pics and writeup. Even better avatar - way2wyrd.
    #7 9 years ago
    Pretty neat. It's a survivor and built to last!
    #8 9 years ago
    There certainly is a bunch of them on ebay.
    #9 9 years ago
    Quoted from way2wyrd:
    --Jeff
    Do you swap in the standard dies that are available?
    #10 9 years ago
    Quoted from pinhead52:
    Its a fixed press. One size only.
    Ill throw it in the tool box and let you take a look at TPF
    --Jeff
    #11 9 years ago
    Not for long now that Pinsiders know about and have access to a cheap tool that works great.
    Ken
    #12 9 years ago
    It will be like those HP flat scanners, once the pinheads find out, they will go from $10 to $90, starting............now.
    #13 9 years ago
    I do a lot of riveting with the ramps I make. I have a rivet press like the one at Pin Restore. While the press works great there are times that due to the location of the rivet the press simply cannot reach it. In those cases I use a hand held rivet tool. First off there are two "dies" to any rivet set. One is concave and supports the head while the business end actually compresses and "rolls over" the rivet bottom. In the cases where I cannot use the press I use a hand held roll over die that is about 4 inches long. To use this die, the rivet head must be supported, then the hand held die is positioned and then with a hammer, you pound until the rivet is rolled over and the work secure. A piece of hardwood can be used to support the rivet head, or in my case I slip the work over one of the jaws of my vise and then hammer away. This tool is available at Hanson Rivets for $25.
    http://www.hansonrivet.com/hand-rivet-clinchers.htm
    Specifically, the Hanson model for the 1/8" semi tubular riveting is Item HT-174
    You can also get this tool for the same $25 price at Pin Restore. At least to begin getting set up with riveting, I'd recommend buying from Pin Restore as they also sell a nice little starter set of rivets and washers. The rivets they provide are nickel plated brass rivets which are a little softer than the steel rivets I use.
    http://www.pinrestore.com/Riveting.html
    Unless you are doing a lot of riveting and want the convenience of a rivet press, this one tool could be used exclusively with great results. I'd be glad to pass on any further info if desired.
    #14 9 years ago
    Got one of these at a yard sale ages ago. Still see them occasionally and flebay has plenty to go around.
    #15 9 years ago
    --Jeff
    I was wondering what the hell that was.
    Now I know.
    #16 9 years ago
    A lot of the ones I'm seeing on ebay have dies that are badly worn down from use. Are there any replacement dies that might fit given that this is an antique? Would the pinrestore dies fit?
    2 years later
    #17 6 years ago
    --Jeff
    Great tip!
    I have a Gottieb Top card resto coming up in the future, has a lot of targets that need replacing. Just ordered one on Ebay...
    This page was printed from https://pinside.com/pinball/forum/topic/riveting-targets-a-new-tool and we tried optimising it for printing. Some page elements may have been deliberately hidden.
