Hello, I'm (still) in the process of replacing a playfield, plastics, and ramps on my Monopoly. I've just transferred all the wiring from the ramps to their new replacements, but the left ramp I purchased didn't have the light brackets pre-riveted.
I know the size, and I know that 2 brackets use semi-tubular rivets, while the one on the end uses a pop rivet. My problem is, I'm not sure what kind of tool I should be using to install a semi-tubular rivet. I've looked around the interwebs and I gather there are hand tools..which is basically a rod that you bash with a malette and it peens the end..which I don't want to do as we're talking about plastic here. I imagine most of the riveting that is done with one of these is metal on metal. The other option I've seen is this squeezer tool but it is really expensive.
Anyone have any experience with this? How did you fasten the rivets?
Mike
