A friend's Riverboat Gambler is having some problems when it starts a game. It will sometimes kick out a ball and reset or just plain reset without kicking out a ball. Other times when it powers up. It starts a cycle of the lift crank assembly on the ramp moves a little, followed by the left drop target solenoid energizing and all the controlled lights will go out and then come back on. I've also noticed that the +5VAC and blanking leds on the MPU board are solidly lit, and the diagnosis led is blinking. The diagnosis and the blanking led will go out when the left drop target solenoid is energized. I've reseated all the connectors on the MPU board and there is nothing that jumps out at me on the MPU board that looks fried. Now when I go into the solenoid test, it will try to energize the fifth solenoid, xx and reset the game. I've reseating all the connectors on the MPU, Power Supply, Auxiliary Power Supply and Interconnect board. Also, I've reflowed the solder on all the connectors on the MPU and Power Supply Board as well. I've noticed on the power supply board that I get 5.01 volts exactly, however for the +12 volt test point I get about +9.5 volts and on the -12 volt test point I get about -13.5 volts. I have a capacitor kit coming for the power supply board since some of the capacitors look original and others look newer. Also I'm thinking the 2N6057 transistor at Q5 on the power supply board could be bad as well so I might change it out as well based on some searches I've run across. Any suggestions on where to start to troubleshoot this?
