Currently shopping out a Riverboat Gambler, and need to take out the right clear ramp to clean playfield & replace bulbs/rubbers. To remove this I need to remove the shaft & diverter arm, and to do that I need to loosen the set screw that tightens the shaft to the crank. Problem is, the hex key hole in the set screw for the crank has been stripped by a previous owner. I would normally use a Dremel cut-off wheel to cut a slot in the screw for a flathead screwdriver but there's no room to get in there. Can't get in there to remove the lock pin (or whatever it's called) from the plastic arm either. My only option is to cut off the top of the shaft above the ramp, but that obviously would destroy it and they are out of stock everywhere. Suggestions? Anyone got a spare diverter assembly or plastic arm leftover from a restoration?
