(Topic ID: 196795)
riverboat gambler
By willie0912
6 years ago
#1 6 years ago
I have a riverboat gambler that just started having display issues.When game is started displays are fine but once anything is hit it shows commas across the top display in addition to the regular and correct displays. When game is over all displays are normal again. Any ideas anyone? Thanks Bill
#2 6 years ago
Try resetting the ribbon cable to display first. Pull and then reattach. Do same with all of the connectors to display as well. Pull off gently, then put back on firmly. During this, inspect all those wires that they are in those prawns in connectors firmly, nothing looks loose.
I have a Jokerz, Fire, and Riverboat gambler and they all have similar displays. Fire is 4 panel but same connectors.
If you just moved it, or been a while since you played, bor played a lot, they jiggle loose and you get what your describing.
Start there and will go to tje board if needed. On older system 11s this is common.
Had a bunch.
#3 6 years ago
Can you post a picture of the MPU board? I just worked on one that had battery corrosion, above and below the battery pack.
#4 6 years ago
Quoted from Ericpinballfan:
This is a good idea. Make sure you reseat it at the MPU and at the display.
#5 6 years ago
changed the ribbon cable and all is well again.thanks everyone for your input,Bill
$ 27.00
$ 29.99
Daddio's 3D Printed Mods
$ 95.00
Pinball Mod Co.
$ 19.99
$ 18.95
$ 27.95
$ 50.00
$ 12.50
RoyGBev Pinball
$ 29.99
$ 54.99
2,000 (Firm)
San Diego, CA
Mod Magic!
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/riverboat-gambler-2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
