Hi, does anybody have any suggestions for keeping a machine higher than normal ? Are there some sort of risers I can get to stand a pinball machine maybe 4 to 7 inches higher than standard? Any suggestions? Thank you.
What machine? What length are your current legs?
Legs do come in different lengths and you can just get longer ones.
Typical new sterns. I’m going to need some clearance if I put it in front of a AC vent. Just enough extra space for the air to pass under the cabinet instead of directly onto it
Quoted from Electronmagic:What machine? What length are your current legs?
I did not know this (:
Who sells this?
34 3/4” are the longest legs that I am aware of and Marco did stock these at one point. So if you can find a set of those then you will be off to a good start and could could a bit higher with longer stem leg levers!
Quoted from acupunk12:Typical new sterns. I’m going to need some clearance if I put it in front of a AC vent. Just enough extra space for the air to pass under the cabinet instead of directly onto it
Could you just add a short duct onto the vent?
They used to sell a plastic quarter round that adjusted in length and has magnets on each end that goes on the vent and defects the air flow up or down. Made specifically to redirect the air on vents.
warm in NJ these days eh?
Quoted from t2:They used to sell a plastic quarter round that adjusted in length and has magnets on each end that goes on the vent and defects the air flow up or down. Made specifically to redirect the air on vents.
Where would I get the Lowe’s?
Thanks (:
Quoted from TheLaw:warm in NJ these days eh?
It’s been a warm January but I usually run through AC eight to ten months a year. Mediterranean blood (:
Quoted from sataneatscheese:I don't know that I'd trust it, but look into "bed risers".
I’ve heard that too I mean they probably work multiple people do sleep on beds and weight more than a pinball machine would (:
Quoted from acupunk12:Where would I get the Lowe’s?
Thanks (:
Yes look up heat/ air deflector
Yep - we have a vent underneath a bench with one of these on the vent, blows it straight out over the floor. Makes sense in the winter, heat rises anyways right?
This page was printed from https://pinside.com/pinball/forum/topic/rising-a-machine- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
