Quoted from JWitty:
I was looking at slides and saw one has number 1n4763 and saw others had different numbers. Does anyone know what every diode number is. I don’t really want to start Desoldering all the diodes to get the numbers from them if someone has them on hand. Thanks.
From the wiki:
Rebuilding the 100 volt Power Supply Section.
If any of the high voltage fuses are blowing, you probably need to rebuild the 100 volt power supply section. You will need to replace the following parts on the power supply board.
Positive System 11 100 volt section parts to replace:
•Q1 = MJE15030 transistor. On older games that specify a SDS201 transistor (which is no longer available), the leads of the MJE15030 transistor must be "twisted" so the emitter, base and collector match the circuit board. You can also use a MJE340 (NPN 300 volt transistor) or a 2N3440 with a "star" heat sink.
•Q2 = 2N5401 (PNP 150 volt transistor).
•Z1 = 1N4730A (3.9 volt 1 watt diode).
•ZR2 (Z2) = 1N4764A (100 volt, 1 watt) diode. Use 1N4763A (91 volt, 1 watt) diode instead (to increase score display life).
•R1 = 39k ohm, 1 or 2 watt flame proof resistor.
•R2 = 680 ohm, 1/2 watt resistor.
•R3 = 330k ohm, 1/2 watt resistor.
•C2 = 0.1 mfd 250 volt metal polyester capacitor.
Negative SYstem 11 100 volt section parts to replace
•Q3 = MJE15031 transistor. On older games that specify a SDS202 transistor (which is no longer available), the leads of the MJE15031 transistor must be "twisted" so the emitter, base and collector match the circuit board. You can also use a MJE350 (PNP 300 volt transistor) or a 2N5416 with a "star" heat sink.
•Q4 = 2N5551 (NPN 140 volt transistor).
•Z3 = 1N4730A (3.9 volt 1 watt diode).
•ZR4 (Z4) = 1N4764A (100 volt, 1 watt) diode. Use 1N4763A (91 volt, 1 watt) diode instead (to increase score display life).
•R4 = 39k ohm, 1 or 2 watt flame proof resistor.
•R5 = 680 ohm, 1/2 watt resistor.
•R6 = 330k ohm, 1/2 watt resistor.
•C4 = 0.1 mfd 250 volt metal polyester capacitor.
The regular (non-zener) diodes all look to be 1N4001 according to the schematic.
