Judge Dredd: The right flipper occasionally gets stuck in the up (pressed) position. Sometimes only very short, sometimes longer. What I have already ensured:
1. it's not a mechanical problem. If the flipper hangs up and I switch off the flipper, then the flipper comes down again.
2. it is not a problem on the power driver board. For testing I used a brand new one from Rotten Dog and the problem remains exactly the same.
In the test T.9. All Lamp Test, the right flipper is also triggered in the blinking cycle of the lamps. That means lamps on, flipper is triggered as if the right flipper button was pressed. Lamps off, flipper goes back to home position.
Thanks for any hints where the problem could be.
Attached is a video of the test: https://drive.google.com/drive/folders/1oI_LkLClSgUKkVKly2gmCLJOFz6jy6kI?usp=sharing
Many thanks
Martin
