Assuming a fuse? Will hit radio shack anyone know if I need a 3 or 5 amp slow blow?
If not a fuse I will check wires and connections. Anything else I should look for ?
Dave
Dave
Fuse should be near it. Pull it and read what is on the fuse, if there isn't a card nearby.
Pull fuse and check with a meter if you can, or swap left and right fuses.
Check for broken wires if not a fuse.
If you replace the fuse and the flipper energizes as soon as you turn the game on, it's probably the transistor.
This page was printed from https://pinside.com/pinball/forum/topic/right-flipper-dead-on-acdc and we tried optimising it for printing. Some page elements may have been deliberately hidden.
