Quoted from docquest:I also had the bump. Repositioning the metal guide rail to be straighter and spaced closer to the flipper made the upper flippers shots more consistent, especially when the ball was.going fast (which is often in this game)
In my case, the top of the inner wood rail was right against the rail. I had to take out 2 screws under the playfield holding the the top portion inner wooden rail to the playfield so I could move the wooden rail along with the metal guide down and straighten it. Once the metal guide was where I wanted it, I secured the wood rail back to the playfield. It only moved a small amount so the same holes to hold the wooden rail to the playfiled were still usable.
Also noticed there was a metal post with a rubber ring on it behind the metal guide rail as well. No idea why that would be there since its inaccessible by the ball.[quoted image]
How did you reattach the metal guide to the playfield as it doesnt appear that you can access the screw holes after moving it.
