Quoted from Lounge:College professor.
Or pig ? Lol
Aren't there pigs or professors in RM?
"Don't think about it (Burraap)!"
Yeah the topic is RM
"Maybe fixate on that, (UrrruP) Morty."
Or pig ? Lol
There’s so much to love about this game. From the company, “the family” (no, not that family, though you never know), the designer, the theme, the interesting layout, the interesting mechs, the limited number, the coders, the quirkiness, the involvement of the creators, the “david vs Goliath” stuff, the art.....
I’m sure there’s better games on one or two points, but as a whole package nothing compares.
Quoted from razorsedge:Here's a thought: 4 ball lock. 5 ball wizard multiball
-Locking one ball on one side, then a second on the same side. Now two on one side.
-With the post up, locking the third ball in behind the vacant drop target/side.
-Two on one side, one on the other side, post down. Need to "knock" all 3 balls to one side.
-With the Closed Off loop, the game logic Could Maybe reliably know that there are still three balls trapped within the horseshoe?, just All on one side (acknowledging the "ghost" ball in the three high position).
-Post Up (when logic "loses" the third horseshoe ball = all 3 on one side). With the fourth ball, knocking drops does not let them fall or release multiball, unless the balls are All on one side with post up. Then only the Vacant lock will drop.
-When there are three balls on one side, and post Up, hitting the Loaded side does not release, but hitting the empty side lets the fourth ball in and locks it there!
-So three balls now on one side, one on the other side. The game reads three balls in the horseshoe, but logically knows where the fourth "ghost" or "lost " ball actually is.
-Now there is a 5th ball only left to play with, which pops out of the portal re-entry!
Start 5 Ball Portal Multiball!! - by hitting Either target which causes them both to drop.
Success would be: Releasing 5 ball multiball with first Jackpot being to restore the "lost" (Morty) ball to the top portal (before MB end). If you have only 2 balls left then the jackpot ends the multiball, no super jackpots. The One Time there would be an intentional unclosed portal loop. To restore the staged ball from the wizard 5 ball multiball.
Fail would be: Not releasing 5 ball multiball before draining. The game drops the single ball from the horseshoe, then you get a hurry up to restore equalibrium to dimensions and continue your game, perhaps a MB restart chance? .... Portal before time is out or the universes all end! (game over).
I know it might give Eric and Scott nightmares to create code for this to work.... but just thought it was something that could be pretty cool!
For mods... a holographic of the spinning portal, on the portal lane/shot, so that the ball disapears into it would be a bit speccy if done well!.
Activates only when the portal shot is lit.
Who out there is into doing the quality digital/displays/video kinds of mods?
Also is there any way the Portal Gun could ever indicate the current dimension, in the game being played? ... a mod to replace the sticker with a little display?
Quoted from razorsedge:Lol .... you didn't read it did you. It's about life and people.... not "money".
Capitalists .... just as bad as the other extremist dirty "C" word. You guys are funny!
You mean Communists, right? Lol
Quoted from razorsedge:Here's a thought: 4 ball lock. 5 ball wizard multiballI
I wonder if three balls can fit between the drop and the post?
Quoted from Iwasthebruce:You mean Communists, right? Lol
"Well, I was aiming for Cronenbergs, Morty .... but er, whatever the people want to fill their imagination with is (BrRRaurrP) fine. Don't worry about it."
I'm sure capitalism isn't really as bad as it looks....
Rick and Morty has lots of imaginary concepts, as does this amazing thread! . Fitting really, and even in some ways, on topic
Quoted from arzoo:I wonder if three balls can fit between the drop and the post?
Good point, I kinda wondered that too.... looking at the placings of the opto cut-outs, it looks like there would be room.... ?
This has been covered by spooky. It can but there are no optos for a third ball on one side so the game would lose track of the ball and not work.
Quoted from Mitch:This has been covered by spooky. It can but there are no optos for a third ball on one side so the game would lose track of the ball and not work.
Well true, but there does not need to be an opto there for logic to be able to determine that there is a third ball on that side (given the right conditions), as described in the 5ball theory.
That is why I posed as a question, "reliably"?
With drops locked up, it is a Closed System. If there Were three balls being detected, then one gets knocked to the other side, the logic assumption is that All 3 are now on the same side (unless of course optos are playing up, which is a problem anyways). So two balls only are being detected now, with the software/logic "knowing" that the third ball is there but obviously not detected (hence trapping it with the pin to ensure it Stays there, while 4th ball is locked).
So, the software Raises the post to ensure they stay there, flagged as the one side definitely having three balls. On to next phase: Lock 4th ball in vacant side.
Yes, it would require a pretty specific sequence of shots to be able to set it up, for the software to "know". Confined to a "mode" even... hence proposing it as a Wizard "mode".
Just throwing ideas out there
I like the theory but I don't think you can rely on it. I can see the one ball not getting knocked over completely, maybe it just makes it to the top of the horse shoe, the computer thinks it's gone over. It then drops the Target on the "empty" side. With the target down the third ball dribbles out making it think the 4th ball entered the horseshoe and the whole thing is off.
So now that weve seen Stern’s latest offering, lets get back to the real discussion.
How about that portal shot? Accessible from two ways depending on what you have lit? Wonder what determines when the diverter is down to allow the right orbit shot or come back for the third flipper shot.
Really like that we can “charge” the portal gun with the spinner. That sounds satisfying. Bet the sfx is satisfying as well.
The garage floor. You can kind of see the effect of the portal light below it, but the angles havent been great yet. Wonder if well be printing a semi transparent portal sticker for that floor or if the effect will be enough.
Also wonder how much of the machine was final final. Did they say? Are the rick and morty decals any larger or different on the drops? Was hoping theyd allow you guys to use a black outline sketch of each one of them so it could still be rgbeautiful and also still look like R or M. The current dots are unobtrusive, but I would see wanting something more later. Just a thick black line outline thats hollow I think might look cool.
Quoted from fnord:I like the theory but I don't think you can rely on it. I can see the one ball not getting knocked over completely, maybe it just makes it to the top of the horse shoe, the computer thinks it's gone over. It then drops the Target on the "empty" side. With the target down the third ball dribbles out making it think the 4th ball entered the horseshoe and the whole thing is off.
That isn't fully the theory I was writing out there though, not quite. The vacant bank drop must Not be allowed to drop at all, untill After 3 ball a side pin is raised, and time confirms it after pin raises. Then and only then can the vacant bank target drop when the 4th ball is aproaching. Lock side drop is forced to stay up if it is hit (or maybe not, as a kind of "fail"). This is what I meant by "closed system", if the drops are forced to stay up untill after three balls on one side is "confirmed" (by time, allowing for "dribbles"), then the situation you describe is no longer possible really.
Considering the scenario, as you describe; If that happened it would pass the empty side optos anyway (in the outward rolling sequence, thereby potentially "knowing" (with code) that the ball did not go all the way or stay there (get captured there 3up). But the key thing is the vacant drop not being allowed to drop until after this "confirmation delay". So, the code should not be allowing the "vacant" target to drop at all until the third ball being on the other side is Confirmed (by "time"). After x seconds the pin is raised. Still no empty side optos triggered during a given time?, THEN after this next time period allow vacant drop/lock to become open when the 4th ball now aproaches it (long opto).
I think the "almost made it" ball behaviour can well be acounted for, I think. Might involve some fancy code though
If it can't be reasonably done then it can not be done. Can't hurt to throw the thoughts out there anyway
Quoted from razorsedge:That isn't fully the theory I was writing out there though, not quite. The vacant bank drop must Not be allowed to drop at all, untill After 3 ball a side pin is raised, and time confirms it after pin raises. Then and only then can the vacant bank target drop when the 4th ball is aproaching. Lock side drop is forced to stay up if it is hit (or maybe not, as a kind of "fail").
Considering the scenario, as you describe; If that happened it would pass the empty side optos anyway, thereby "knowing" the ball did not go all the way or stay there (get captured there 3up). Also, the code should not be allowing the "vacant" target to dropat all until the third ball being on the other side is confirmed (by "time"). After x seconds the pin is raised. Still no empty side optos triggered during given time, then allow vacant drop/lock to become open when the 4th ball now aproaches it (long opto).
I think the "almost made it" ball behaviour can well be acounted for.
"Don't break your back creating a lesson Morty, It's a free form anthology, I'm getting annoyed you're not hearing that."
Quoted from gliebig:Like what I see but do think it would've been cool to have a portal shot similar to LOTR ring shot.
Nah, this isnt a company that rehashes the same ideas over and over, sorry.
It would be kind of cool that if there was some logic in there that let you release balls using the kinetic hitting. Say you have 2 balls stacked on the left side, you hit the left side which forces a ball to the right side and it opens the gate and lets it out. Vice versa...something of that nature.
Quoted from Chitownpinball:So now that weve seen Stern’s latest offering, lets get back to the real discussion.
Also wonder how much of the machine was final final. Did they say? Are the rick and morty decals any larger or different on the drops? Was hoping theyd allow you guys to use a black outline sketch of each one of them so it could still be rgbeautiful and also still look like R or M. The current dots are unobtrusive, but I would see wanting something more later. Just a thick black line outline thats hallow I think might look cool.
Well they did mention that Pickle Rick would somewhere else on the PF so obviously not final/final.
The main thing for me is that the portal shot is satisfying to shoot. So it has to do something to make it a satisfying shot. And yeah, and really cool portal swirl effect would be nice.
Quoted from Zablon:It would be kind of cool that if there was some logic in there that let you release balls using the kinetic hitting. Say you have 2 balls stacked on the left side, you hit the left side which forces a ball to the right side and it opens the gate and lets it out. Vice versa...something of that nature.
That's a fun idea. A non automatic release multi-ball where you have to knock them out to release them. It could then release the last one when you drain out your free balls. This is going to be a really fun mechanic.
Quoted from Fytr:Well they did mention that Pickle Rick would somewhere else on the PF so obviously not final/final.
He said "he will be hidden in the game" not specifically on the PF so may or may not
The thing about the portal shot is it's basically like shooting a left orbit (I think they said you can do it from the right orbit as well). The problem here is...that doesn't seem to lend itself to a satisfying shot...at least in any game I've ever played. Now, I assume since it goes from there to your left flipper every time, there will be a bunch (hopefully) of different combo skill shots set up from left flipper to be made related to whatever mode it goes into.
Generally satisfying shots usually are on difficult ramps or something that is impacted by the shot (dropdowns, bash toys etc). I think what will be important is the outcome of how the 'adventure' ends. Do you play only 1 adventure at a time? Do multiple adventures play out at the same time? I'm not sure I see any potential 'satisfying' shots here, but much of that will come down to rulesets. EDIT: I guess the whole left orbit to upper right flipper (which I keep forgetting about) and up the ramp, etc will be those shots.
Quoted from Zablon:The thing about the portal shot is it's basically like shooting a left orbit (I think they said you can do it from the right orbit as well). The problem here is...that doesn't seem to lend itself to a satisfying shot...at least in any game I've ever played. Now, I assume since it goes from there to your left flipper every time, there will be a bunch (hopefully) of different combo skill shots set up from left flipper to be made related to whatever mode it goes into.
Generally satisfying shots usually are on difficult ramps or something that is impacted by the shot (dropdowns, bash toys etc). I think what will be important is the outcome of how the 'adventure' ends. Do you play only 1 adventure at a time? Do multiple adventures play out at the same time? I'm not sure I see any potential 'satisfying' shots here...
It's the upper right flipper shot, so yeah, more difficult. I just mean that when you nail it it should do something impressive to make you feel like you did something. Hopefully it's fully visible to the player too and not hidden.
Quoted from Chitownpinball:Nah, this isnt a company that rehashes the same ideas over and over, sorry.
That's the reason I said Similar. According to your logic, they shouldn't use ramps/pops....
I would've like to seen something a little cooler with the portal shot. Who knows, maybe after some more vids, it may be pretty cool. Can't wait to see what this pin becomes.
Yeah, I had hoped that the portal shot would be more like the ring shot in LotR where it went airborne off a ramp and into a hole in the backboard that represented the portal (backlit in green or something). That would have given a ton of impact to the ball materializing in the left inlane right after it flew through the backboard. Oh well.
Quoted from DanQverymuch:Thinking about the build order thing, not that it's a big deal, but if all standards are to be built after BSEs, then won't that mean that unless all distributor buyers went BSE, they are going to have to revise the list and lower most numbers? Either that or build the lower numbered standards out of order at the end?
Quoted from Gryszzz:TWISTED PANTIES
Take two.
ACTION!
Hey, it's a legitimate question, one that would make you wonder as well, had you any critical thinking skills.
All of the standards at the end of that cobbled together list are from direct orders, and there is no gap for standards through distribs. So either
1) all distrib orders are BSEs (unlikely)
2) the distrib standards get built in number order, before all BSEs are done (not as promised)
3) the distrib standards' slots get moved to the end, and most BSEs move up some small number of slots, and renumbering happens
4) the distrib standards get built at the end, built out of number order, so again most BSEs get built slightly sooner as in #3 but they leave the numbering alone
None of these scenarios are ideal, and none of it is earth-shattering, but logically one of the four must occur due to the system they used for the ordering.
No PANTY TWISTING involved, except maybe on your end if you can't wrap your head around the admittedly insignificant issue. I'm just curious how they're going to handle it is all.
EDIT: I presume it will be either 3 or 4, so it's all good news, most BSEs would be built slightly sooner than we thought, depending on how many distrib standards were ordered and where they sit in the list.
Quoted from razorsedge:It didn't move on though did it. Quotes a guy from a few posts earlier calling Spooky "dumb" for rejecting capitalism.
Capitalism is the truly dumb shit Lol
Along with the guy thinking he can run a Boo-tique pinball company better than Spooky does. If you want a capitalist pinball company that only cares about money, then go buy a stern box.
You do realize that Pinball machines wouldn't exist at all without raw American Capitalism right?
I don't see a lot of Communist countries producing Pinball machines....weird?
Quoted from Fytr:The main thing for me is that the portal shot is satisfying to shoot. So it has to do something to make it a satisfying shot. And yeah, and really cool portal swirl effect would be nice.
So a teleporting ball “instantly” coming back into your left in lane isnt satisfying for you? How about if they made it owner controllable how fast it comes back into the lane? Its basically a wireless ramp and ball return method lol. If its as fast as they say its gonna be sweet.
To me, combo shots with loops to finish are super satisfying and this game looks like it will have those shots.
Its not like you are going to want to change dimensions over and over, so you will most likely avoid it until you need it.
Quoted from donkadelic:You do realize that Pinball machines wouldn't exist at all without raw American Capitalism right?
Eh, he's not bashing capitalism, he's bashing greed. There's a difference...and let's not kid ourselves, greed is alive and well in the pinball community and in corporate america in general.
Quoted from zucot:Anyone hear from Joe lately?
Nope...some said he had a family emergency so probably best to let him sort this out on his time.
Did he say if he had any other blocks other than 51-59?
Quoted from Zablon:Eh, he's not bashing capitalism, he's bashing greed. There's a difference...and let's not kid ourselves, greed is alive and well in the pinball community.
BAM! Take that Greedos!
38C7EE93-6580-49B9-9096-90E6A6400A91 (resized).jpegQuoted from gliebig:Did he say if he had any other blocks besides 51-59?
He has said he has 100 games. So probably spread across the entire run 10 blocks of 10 I would imagine. Just a guess.
Quoted from Chitownpinball:Its not like you are going to want to change dimensions over and over, so you will most likely avoid it until you need it.
Unless the dimensions are stackable...
Would be cool to show the current scoring formula on the LCD if you could get a bunch of scoring modifiers going at once. He's already involving divisors, could get complicated..
Quoted from Chitownpinball:So a teleporting ball “instantly” coming back into your left in lane isnt satisfying for you? How about if they made it owner controllable how fast it comes back into the lane? Its basically a wireless ramp and ball return method lol. If its as fast as they say its gonna be sweet.
Well, I haven't shot it yet nor seen a real gameplay video. Maybe it is, maybe it isn't. All I said it is better be!
Quoted from estrader:Nope...some said he had a family emergency so probably best to let him sort this out on his time.
Didn’t know that. Thanks for the context. Hope everything is ok.
Quoted from Fytr:It's the upper right flipper shot, so yeah, more difficult. I just mean that when you nail it it should do something impressive to make you feel like you did something. Hopefully it's fully visible to the player too and not hidden.
This can easily be implemented by having pulsing light show waves originating from the back left corner across the playfield with different greens.
Quoted from razorsedge:if the drops are forced to stay up
Keep in mind that the drops are stock parts so they can't be locked in the up position. But they can drop and immediately reset, so that's basically the same effect.
Quoted from DanQverymuch:Hey, it's a legitimate question, one that would make you wonder as well, had you any critical thinking skills.
I wasn't even referring to you Dan but Merry Christmas to you too!
Quoted from arzoo:Keep in mind that the drops are stock parts so they can't be locked in the up position. But they can drop and immediately reset, so that's basically the same effect.
Yep, I think that's what the single drop in STTNG does.
Quoted from Gryszzz:I wasn't even referring to you Dan but Merry Christmas to you too!
My apologies, sure seemed like it. Quoting can avoid these misunderstandings ya know.
I mainly wanted to bring it up again, so I used that as an excuse. Guess there are more important things to worry about.
Merry Christmas! Have a cool yule!
Quoted from RandomGuyOffCL:Boom just got my confirmation email
Joke post in case you take this seriously
Bullshit!
Quoted from 6S3NC3:He said "he will be hidden in the game" not specifically on the PF so may or may not
My hope is for pickle rick to be in the same place on playfield, but be printed in uv ink so you can’t immediately see it. When game uv turns on, you will see pickle rick and this would make it a pinball first.
'Twas the night before Christmas, when all through the house
Not a creature was stirring, not even a Slot #.
The stockings were hung by the chimney with care,
In hopes that Rick and Morty would soon would be there.
Nope !!
WTF ,
Quoted from jeffspinballpalace:My hope is for pickle rick to be in the same place on playfield, but be printed in uv ink so you can’t immediately see it. When game uv turns on, you will see pickle rick and this would make it a pinball first.
Does the game have UV lighting?
Quoted from Airball:1 week later and still no Numbers from Pinballstar.
Is it that difficult to figure out.
Quoted from Airball:'Twas the night before Christmas, when all through the house
Nope !!
WTF ,
If this is the biggest problem in your life count your blessings!
Quoted from Zablon:Does the game have UV lighting?
Don’t know, but they could aim a spot light and use a uv 555 bulb. Should be enough for the effect, but it needs to be a controlled lamp.
Maybe it's a joke that I just don't get but it is hard for me to see this post:
Right before yours:
Nope !!
WTF ,
and not think your priorities are a little... out of whack.
This page was printed from https://pinside.com/pinball/forum/topic/rick-amp-morty-pinball-from-spooky/page/118 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
