Quoted from scampcamp:On my Twilight Zone the color DMD was having glitchy Behavior and a Pinsider was telling me that he usually replaces the ribbon cables when he goes on house calls if the game is 15 years old or so... as in regular maintenance for the game. He is sending me new ribbon cables.
Do you replace your Ribbon cables only if something is not working or as a regular maintenance type of thing?
I've never replaced them as part of preventative maintenance, although I have been known to pull them out and clean them if they're disgustingly filthy. If your DMD is exhibiting "glitchy behavior", the ribbon cable is a good thing to look at or replace. However, in terms of "regular maintenance", in my experience, those ribbon cables/connectors are just as reliable, if not more reliable than all the IDC cables/connectors in your TZ backbox. I'm always careful when I fiddle with ribbon cables because it's easy to accidentally bend a connector pin on the circuit board... or connect a cable improperly (the ribbon cables are not keyed).
A few years ago I had an STTNG that worked perfectly, except I noticed that the shield lamps never dimmed. They were on or off, but never dimmed like they were supposed to. A real head-scratcher. Wanna guess what the problem was? One pin (the zero cross signal) on the ribbon connector between the CPU and power driver boards was bent over, not making a connection.
