What do you mean by more stable? Were there screen tearing issues or other artifacts before?
Quoted from Crash:What do you mean by more stable? Were there screen tearing issues or other artifacts before?
Im not sure yet, because of boards were USB defective by design mistake. So do not know if improvement by buffers was real or USB mistake damaged some IO port, I will know along this week with new board.
Quoted from lucky1:» YouTube video
contact unclesash on vpuniverse.com about the rest
i want this for Ghostbusters !
Just received my PIN2DMD kit this week. Booted it up, now waiting for my key to continue . Could someone tell me how to get started from here? It's going to be mounted in my Getaway, could someone steer me in the right direction of getting it colorized? I understand Steve45 from vpuniverse has the same setup, regretfully the files are not (yet) for download
Quoted from DorkVonWaterfall:i could also need a file for a GnR as i can`t get the editor tool working.....
I have tried it on a GnR but Data east only has 4 grayshades eg you can only select 4 colors which remain fixed during the whole game and than it is not easy. As I already had a colordmd in my GnR I didn't spent more than 15 minutes in this. I think perhaps shades of red are perhaps best choice
If you wanna get pin2dmd editor working choose the 32bit version and don't forget to install the license key !!
Apparently pin2dmd editor has the possibility to colorize frames like colordmd but that's a time consuming task. Not for me
Quoted from mgpasman:Just received my PIN2DMD kit this week. Booted it up, now waiting for my key to continue . Could someone tell me how to get started from here? It's going to be mounted in my Getaway, could someone steer me in the right direction of getting it colorized? I understand Steve45 from vpuniverse has the same setup, regretfully the files are not (yet) for download
Simple. Put the key on SD card. Make a fixed color palette to your liking with pin2dmd editor, export this as palettes.dat file on the SD card and ready to go
However, fully colorizing each animation in place of 1 fixed color palette is a different cookie .....
With the pin2dmd.exe program you can control for instance brightness
All to be read in Spinner 2 or more likely 3
Quoted from Rensh:Simple. Put the key on SD card. Make a fixed color palette to your liking with pin2dmd editor, export this as palettes.dat file on the SD card and ready to go
Cool. Maybe you need help or input for that article?
Hm, I seem to be stuck again. The pin2dmd.exe program starts, but won't let me do anything useful. I am trying to run the program standalone, not connected to the board. I can select proper mode, but cannot save palette or config file. I can click the buttons, just nothing happens.
Using pin2dmd-editor (the Java thing) I was able to create a pin2dmd.dat file, so the display now works (starts up in WILLIAMS mode, and can display real DMD data) but I would still like to modify the palette.
I must say the learning curve is pretty steep. There seems to be no "getting started guide" for this, everything has to be found out Googling, and information is scattered between this forum, flipperforum.de and vpuniverse.com.
Quoted from c_mario:have you seen the authors editor documentation?
http://pin2dmd.com/editor/
Yup, but it mostly dives into the colorization of frames/animations, but for now I would be happy if I can create my own palette. Using the editor I think I can only create few default config files (pin2dmd.dat), the one using VGA colors (shown on photo) or some basic colors.
I tried modifying the default palette as Rensh mentioned, but when I try to save it, it does not offer palette.dat format (just XML or JSON), whereas the pin2dmd.exe tool can only read .dmc files. And so far I have not been able to make the dmd2pin.exe tool save any file to my SD.
Quoted from mgpasman:Hm, I seem to be stuck again. The pin2dmd.exe program starts, but won't let me do anything useful. I am trying to run the program standalone, not connected to the board. I can select proper mode, but cannot save palette or config file. I can click the buttons, just nothing happens.
I told you that you need to be connected to the controller (microUSB) when you use pin2dmd.exe. There is nothing to do with this tool offline.
Quoted from mgpasman:.
You need to use "export" to save your palette as palettes.dat. That is written under 2.1.3 of the editor tutorial.
Quoted from lucky1:You need to use "export" to save your palette as palettes.dat. That is written under 2.1.3 of the editor tutorial.
Yup. Export is required and tool pon2dmd.exe needs to be connected to PCB
I will sent you my article when the draft is finished and you can input. Thanks for the offer. Pls do note however the article is not meant as a manual but to let people become aware that things like pin2dmd exist and what it can do for them and how it looks like
Pls don't forget to register the pin2dmd editor with same key as licky1 sent you
I am sorry, at first I thought pin2dmd.exe could be used both online and to program SD card. Now I know the main purpose of that program, I think I need to stick with the -editor.
The reason I am avoiding working "on-line" is that my laptop only has USB 3.0 ports. I was hoping it could all be done using SD cards.
Yes, I found that. When I save it to SD (next to pin2dmd.dat) and reset the board, it seems to ignore it. When I remove pin2dmd.dat and reboot, (I think) it reads palettes.dat, but then it's in VIRTUAL PINBALL mode (so it wont display any data sent from pinball machine).
Btw I appreciate all help that is given, and I have all intentions to create a getting started document that captures everything I had to learn so far .
That's strange. I have pin2dmd.dat and palettes.dat on same sd card
I did notice however twice I had to set it to a mode I didn't want (like wpc) and than set it to stern befor it accepted stern
Pin2dmd.dat is required I think to determine which mode (stern, virtual, etc) and I think it also contains simple palettes data you can set in pin2dmd.exe. However when it finds a palettes.dat file the palette in there overrules the 'simple' palet. However, this is my thinking and not 100% certainty. That's for lucky1 to give
Smartdmd incolor works with palettes.dat, see my
Cool, now it seems to work here as well . I read somewhere it takes colors 0, 1, 5 and 15 from the palette, but that does not seem to be the case, it takes 0, 1, 7 and 15 (at least, in WILLIAMS mode).
I found that on my netbook, I can configure the USB port to operate according to USB 2.0. So, I can now do both: Create dmd2pin.dat and palettes.dat using the -editor, and communicate directly to the board using dmd2pin.exe.
Kudo's go to Lucky1 and Steve45 for their effort and patience with the community!
I created a guide that documents all steps I went through, I posted it to http://vpuniverse.com/forums/topic/2555-getting-started-replacing-a-dmd-with-pin2dmd-using-sd-card/ (since that seems to be the most comprehensive source on pin2dmd.
Quoted from mgpasman:Cool, now it seems to work here as well . I read somewhere it takes colors 0, 1, 5 and 15 from the palette, but that does not seem to be the case, it takes 0, 1, 7 and 15 (at least, in WILLIAMS mode).
I think you don´t run the latest 2.10 version of pin2dmd firmware. There was a bug with the color mappings. Should be 0,1,4,15 in the latest version of editor and firmware.
Quoted from lucky1:I think you don´t run the latest 2.10 version of pin2dmd firmware. There was a bug with the color mappings. Should be 0,1,4,15 in the latest version of editor and firmware.
It came preloaded (from Rappelbox) with 2.09 I believe. Will look into updating that.
Quoted from Rensh:That's strange. I have pin2dmd.dat and palettes.dat on same sd card
Smartdmd incolor works with palettes.dat, see my » YouTube video
Interesting phenomenon in the thumbnail. Looks like either the camera captured the white background independent of the red text or the RGB panel is experiencing some screen tearing with the text plane, but not the background plane... is the text flashing between red and black? That might explain it.
Hmm didn't notice that while playing. To busy keeping the ball in play I guess
What I can syate is that the upper led display looks in real life MUCH better as captured on film. On film now the LCD looks much better as led while in real life this wasn't.
Quoted from fastpinball:NW Pinball Show is coming up FAST! I will start building tonight and finish Friday when the rest of the parts arrive. So fun.
Aaron
FAST Pinball
What kind of kits are you going to have available? Fully plug and play, or screen only, or some combination of the two?
Quoted from redundor:What kind of kits are you going to have available? Fully plug and play, or screen only, or some combination of the two?
It is a plug and play solution. I am so excited. I was up til 6am building the first few for design testing.
We will also be selling them without the RGB DMD panels for those who bought the panels from us already. Selling with or without the panels doesn't change the shipping costs but some folks were very eager to get started and we wanted to have the panels be interchangeable anyway because they may need replacement far before the controller board ever would.
We won't have them for pickup at the show, but expect to have them in some games and (assuming all the testing goes smoothly) in production ASAP. Sourcing is all established already. This has been such a rad project. I have waited literally years for all the stars to align to have it make sense do to this!
Aaron
FAST Pinball
PS: The few parts I was waiting for came in while writing this post. Sweet!
Quoted from fastpinball:It is a plug and play solution. I am so excited. I was up til 6am building the first few for design testing.
Aaron
FAST Pinball
Interesting. Assuming this would, in one way or another, be compatible with the FAST board system?
Quoted from Coyote:Interesting. Assuming this would, in one way or another, be compatible with the FAST board system?
As a display, it will work with different pinball hardware controllers (using the pc to control the display content), ours obviously included.
From there it gets interesting. I think what we have cooking is going to draw in more people interested in making and programming and enhancing pinball games.
Aaron
FAST Pinball
Aaron
FAST Pinball
That sounds pretty awesome! I will definitely have to come check it out if I manage to make it down to the show. My x-men DMD has a line stuck on and I have been watching this thread to see what develops. Any word on pricing yet? Even a ball park number?
What did I miss?Aaron what is that new board young r there? I see no other talk of it on the forum .....
Quoted from agodfrey:What did I miss?Aaron what is that new board young r there? I see no other talk of it on the forum .....
We weren't just sourcing RGB DMD panels to sell them raw.
Our board will be sold with and without the RGB Panels for those who bought panels from us in the past.
We haven't been talking about this because we are trying to break the habit of talking about things too much before they can be purchased.
Really excited. I have wanted to make this display for years. We have been watching the price and pixel size come down on the panels to the point where it made sense to do it. Time is now!
Aaron
FAST Pinball
Quoted from fastpinball:We weren't just sourcing RGB DMD panels to sell them raw.
Aaron
FAST Pinball
Sure glad to see the market adopting this concept! How does your product relate to PIN2DMD or the new ColorDMD LED product?
It won't be a confusing scattered mess like pin2dmd
(awaits flame responses lol)
@FAST do you have rough pricing yet? Will it be running stock rgb.dmd firmware? or customised version for fastPinball?
Quoted from russdx:It won't be a confusing scattered mess like pin2dmd
Oh wow, I missed this post ages ago! Our price goal all along has been to stay under $300. The RGB.DMD code is customized to do some things needed for some of the other features in the display.
Aaron
FAST Pinball
I'm thinking about getting the fully assembled PinballSP DMDST32 kit from Louis. Question, this is going to be for a Data East game. I don't see any pictures of the kit used in a Data East system. I know it can be done and the PIN2DMD software is compatible with Data East. My main concern is how would I fit the DMD driver board on the back of this whole assembly and will there be enough room in the backbox for this? Plus, I only see 4 holes in the mounting plate, one in each corner, and none in the center on top or bottom to suggest how this driver board would be mounted.
Aaron is your full kit available to buy?
Quoted from dung:Aaron did you ever get the full kit together? Also, has anyone tested this on an alvin g?
Our FAST RGB DMD is back and running. I don't have access to an alvin g. Maybe someone in the Washington area would let us bring a display by for some testing/get some readings.
We had the display at Expo in the FAST Booth in Fish Tales, TOTAN and in the Brooks & Dunn. Super fun. Dialing in the software portion and also the power integration. Tapping into the 12v supply is easier and more reliable in some games than others. So we want to make sure we provide options for the best results before a broad release. It looks like the $299 price point is going to work too, which was a big goal. There are some other rad features about it that we will layout in detail soon too.
I have been dragging a bit. Been pretty sick since we got back from Expo and finally on the mend. I have shipments, website updates and correspondence to catch up on!
Here are a few pics I had handy of the display.
FAST RGB DMD Front
FAST RGB DMD Back
FAST RGB DMD in Brooks & Dunn
Aaron
FAST Pinball
PIN2DMD has been successfully tested on Capcom Airborne and Pinball Magic as well as on AlvinG PistolPoker
Does anybody happen to have one of Eli's small Teensy shields available? I would like to try a couple things out, and I don't need the full Pin2DMD experience.. Thanks
This page was printed from https://pinside.com/pinball/forum/topic/rgb-led-panels-for-dmd-replacement/page/20 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
