Quoted from djb_rh:And that's why it's not open source.
If this were open source, most owners would simply say "hey, new hardware is fine as long as the hardware designer contributes the software patches required to keep it working." Yes, that's still SOME work making sure their patches don't suck, but that's what most open source folks do. Some owners say "okay, this is fine, but you need to contribute each major revision of hardware to me so I can help make sure it works, too." Most hardware folks are pretty happy with that kind of thing.
And some open source people say "it's not our problem, the only hardware we support is XYZ." Then if the person really wants to run your software anyway, they simply distribute your source code along with whatever patches they needed to make it work on their hardware and you don't have to care.
But since you've locked it up, they can't even do that. That's your right, but...
It's not open source. Would make sense to remove that moniker from your web pages, IMHO. It's going to continue to confuse people.
--Donnie
Open source does not automatically mean "free". People tend to confuse the two.
Open source simply means that the source code is openly available for viewing.
Many open source products are also freely available in addition to having the source code openly available for viewing, hence the correlation. However, that's not always the case.
