(Topic ID: 282535)
RG6 Crimp Tool - Stuck
By scampcamp
    #1 3 years ago
    This is way off the pinball topic but was hoping someone could help me get my coax crimp tool unstuck.
    I tried crimping the RG6 connector in wrong spot on the tool so basically it wasn't able to fully reset & release pressure.
    I've tried removing screws & tapping with hammer.
    Any ideas? Thanks
    20201128_005317 (resized).jpg20201128_005317 (resized).jpg20201128_005322 (resized).jpg20201128_005322 (resized).jpg
    #2 3 years ago
    That internal tab at the top of the plastic handle covers won't release it?
    #3 3 years ago
    Tap it hard
    d493afe293e165190bd2e11febb4dbd3bae864a3 (resized).jpgd493afe293e165190bd2e11febb4dbd3bae864a3 (resized).jpg
    #4 3 years ago
    You could try putting it in a vise and apply some pressure.
    That could damage the tool, but perhaps it will move it enough to release that tab easily.
    #5 3 years ago
    If you get desperate, you could use a drill bit the right size and destroy that connector that is lodged in the tool, by drilling it out near the size of the tool jaws until it collapses.
    Just be careful and don't get too aggressive and damage the jaws of the tool.
    #6 3 years ago
    Quoted from vid1900:
    Tap it hard
    Thanks vid1900 ! That did the trick
    #7 3 years ago
    For what it’s worth, I switched from the traditional DIY crimper tool you are using, to the compression type after watching my Xfinity technician. He explained that at higher speeds, the amount of contact between cable and connector matters, and the compression type make a better joint. I got the tool at harbor freight which comes with a dozen compression connectors too. You can get compression connectors on Amazon cheap.
    After using compression connectors, I would never go back to old school...
    This page was printed from https://pinside.com/pinball/forum/topic/rg6-crimp-tool-stuck and we tried optimising it for printing. Some page elements may have been deliberately hidden.
