I did some more research and hooked my scope to the coin door interface J9 (this is the connector where a ticket dispenser should be installed).
I confirm there's no signal at all coming on the pin that should enable the dispenser's motor.
I then suspected that the "tickets low" signal (sent from the dispenser to the pin) could be a problem also. This signal remains High by default (pull-up resistor on the driver board), and I first thought that it should remain that way to be only driven low by the dispenser's logic in case of no more available tickets, which is the logical and usual way of doing things.
But since it did not work, I took another approach: maybe the pinball uses this signal to determine if a ticket dispenser is installed or not. In that case, the dispenser should take the signal low to let the pinball know it's ready, and so, a high value for this signal would be interpreted as either "no tickets" or "no dispenser attached".
So, I forced this signal to low, aaaannnddd........
Nothing !
I put the score award to a ticket for 5.000.000 pts (which is nothing in RFM) and played some. Nothing ! No signal on that bl00dy motor signal.
On one instance, I got a match at game over (for which I also set the award to "ticket"). The display showed something like "1 credit added" or something likewise, but nothing else.
I must confess I'm running out of options, and would really appreciate if someone, former operator or owner of an RFM ou SWEP1 could show up and confirm (s)he successfully hooked a ticket dispenser to that thing in the past.
Furthermore, if someone with a ticket dispenser could do the test, this would also be very helpful here.
On the other hand, there *are* (I know that for sure) people out there with deep knowledge of the pinball 2000 software. Maybe some source code is also to be found somewhere.
Should anyone got a grip on this, could he have a look to see if the needed code for activation of a ticket dispenser is, indeed, present ?
Because, I'm beginning to suspect that this is rather something missing in the software than a hardware issue...
If I can make this thing work, I would publish here all the schematics and mounting plans so that everyone could build his own real knocker for pinball2000. Would be great, isn't it ?
Many thanks in advance
