I've been spending almost 2 days looking over all the switch diodes, and trying to figure out what's causing this, all diodes test .5v +- 10% on all switch diodes. And 0 in the other direction. I added a picture 20210401_105629 (resized).jpg of the switch diode in case I reversed it, but it's situated like all the others, with current flowing from the white wire to the other side of the switch.
If I disconnect switch 15, the trough (ball#4) works fine, and doesn't cause anymore headache, no other issues on the playfield, except the dot on the droptarget coil/switch, which is a given as it can't see the target's state because the switch doesn't fire.... Here's me manually manipulating the switch (the deflector panel is on because the playfield is up) :
https://photos.app.goo.gl/PCeUMCbS9ysZUyd69
If I had issues with another switch, I think I could figure that out, what boggles my mind is that the two systems are in my mind completely un-related as the trough is bound to the opto board below the playfield, and the switches are all coupled to the power driver board. I mean there must be a correlation, it's just not what I'm used to seeing. I mean it is strange that the opto and the switch share the same row, but again in the wiring I can't find where they share anything. Sorry the schematics had a lot of mold or mildew whatever on them.
Is this "Common" on a RFM? To have switches interfere with opto boards?
