Can anyone shed some light on my lamp issue please! It's driving me nuts. There seems to be some voltage bleed over (for lack of a better word) between some lamps...and it doesnt seem to follow even a single row/coloum, but multiple.
Basically, as some lamps turn on/off, part of their power is driving other lamps ad well. So, if the other lamp is nomally off, it glows a little; normally on, it glows brighter than it is supposed to...
for clarification....if you do an individual lamp test, some are ok; while others cause additional lamps (mostly 1 sometimes 2+) to come on dimly (even though they should be off).
I hope my problem is described in a way that makes sense....and that someone can...HELP...
Thank you to all!
