(Topic ID: 187348)
RFM Pin Box Woes: Ghost In The Machine
By nerdygrrl
5 years ago
  • 10 posts
  • 4 Pinsiders participating
  • Latest reply 5 years ago by nerdygrrl
#1 5 years ago
I picked up an RFM that is running PinBox and that is booting to the Select Game Pricing screen. I have a key board and mouse hooked up , but I cannot select any countries. It seems frozen. Is there something I am missing? Some kind of command or something else that I need to do.
I cannot coin up a game until the pricing has been set.
Solved: Coin Door is not wired correctly. Can maneuver down by coining up right slot. Does anybody have a pic of the wiring? I included what I have down below.
NOT SOLVED: While the coin door is acting erratically, all of the wiring checks out. I spoke to the previous owner he said the only thing he's done was build a Pin Box computer. He stated the game was working fine, his friend installed the software after his original computer failed and he could not get it out of the menu you see below.
#2 5 years ago
First problem sort of solved. My coin door does not appear to be wired correctly-thus the inability to go up or down in menu and select setting. Anybody have any pics?
#3 5 years ago
NOT SOLVED: While the coin door is acting erratically, all of the wiring checks out. I spoke to the previous owner he said the only thing he's done was build a Pin Box computer. He stated the game was working fine, his friend installed the software after his original computer failed and he could not get it out of the previously mentioned menu you see.
All of the registering for the coin door is off including open/closed sensors and tilt sensors.
Any ideas? Has anyone seen this before?
#4 5 years ago
I see you did post once in the RFM thread but you should post all the pictures & descriptions in there for more visibility:
https://pinside.com/pinball/forum/topic/rfm-hillary-come-here-you-gotta-see-this
I have replied to your post on that thread to get the ball rolling hopefully.
#5 5 years ago
Many thanks. I am at a total loss here. I just don't wat to go through the trouble of tracking down new software, etc if that is not the problem.
#6 5 years ago
This is likely a communication issue with the driver board. Ensure that the parallel cable from the computer to the driver board is connected and fully seated at all connector points.
Depending on when the game was made, there may be an interconnect that the parallel cable goes through at the back of the head. Ensure everything is solid there as well.
Replace with a known good parallel cable if all connections are good.
Rob Anthony
Pinball Classics
http://LockWhenLit.com
Quality Board Work - In Home Service
borygard at gmail dot com
#7 5 years ago
Thanks! I will give this a try! and maybe pickup a new cable while I am at it.
#8 5 years ago
Also make sure and get a decent quality cable. Some of the cheap chinese cables skimp out on half the internal wiring. While it would likely work for most old parallel printers it would not work for P2K.
#9 5 years ago
Cool, I've ordered a cable and it should be here tomorrow. I'll rule that out first before attempting to re-install the software.
#10 5 years ago
I just tossed the new cable in and we are up and running!!!! Many thanks guys. You saved me a lot of headaches.
$ 79.00
PinballReplacementParts
5,500
Hilton Head Island, SC
$ 349.95
Pin Stadium Pinball Mods
Gweem's Mods
$ 11.95
5,000
Escondido, CA
$ 8.99
Inscribed Solutions
5,000 (OBO)
Peru, IL
$ 46.99
Lee's Parts
