Wordy... skip ahead to #3 if you only want new material
I'm currently dealing with three nagging problems...
1) Vertical upkicker needs to be rebuilt. No big deal, I'm expecting a VUK rebuild kit to be delivered today, and hopefully I won't run into any problems.
2) I simply cannot figure out why the Left lane kicker ("Laser Kick") locks on as soon as the machine is turned on. I've disconnected the coil to prevent it from cooking, but something here isn't right. I changed out the diode, the transistor tests ok. I've followed the wiring looking for a broken or crushed wire and come up empty handed. The playfield switch that activates the coil also tests ok. Stumped.
3) My current frustration... lighting for the pop bumpers. The pop bumpers *work* just fine. The rest of the playfield GI is working fine. None of the pop bumpers are lit. The bulbs are good. For some reason, the pop bumper lighting is treated as a flasher in the manual. I can't find a plug that's been disconnected, or anything of the sort. All other flashers are working fine. Flashers are all on two fuses, both of which are good.
