New! Dark mode!
(Topic ID: 233335)
Revised RAD CALS for many more WMS games
By Highclasspinball
1 year ago
  • 408 posts
  • 156 Pinsiders participating
  • Latest reply 1 day ago by shokel328
  • Topic is favorited by 88 Pinsiders
    There have been 92 images uploaded to this topic. (View topic image gallery).
    There are 408 posts in this topic. You are on page 8 of 9.
    #351 4 months ago
    Quoted from yaksplat:
    Keep in mind that every bolt puts pressure on the surface of the radcal and will create distortion on the surface. That's why I recessed my bolts on the whirlwind. The bolts are also for reinforcement and would never have to be removed.
    Very good points! I just redid my Taxi (decals, then 4 coats of auto-clear), only to have small donut sized rings around 2 of the head bolts. I even backed the pressure off those 2 bolts, but donuts would lie down (finger massage them down) and always come back
    #352 4 months ago
    Problem with recessing the bolts is that you have to destroy the radcals if you ever need to disassemble the pin again. If you want accessibility without covering the bolts, you could also cut your radcals around the bolt heads - no donuts, but still have ability to disassemble. The radcals cut really nicely with a forstner or regular drill bit.
    #353 4 months ago
    Quoted from Boslaw:
    If you're disassembling the head down to boards, you've got a larger issue than some radcals getting messed up.
    #354 3 months ago
    Eagerly awaiting TZ. I am surprised this one hasn't already been made, considering the market potential (and the unfortunate fading issue).
    #355 3 months ago
    Does anybody know if the $365 US shipped price is still valid?
    #356 3 months ago
    Tz and sttng are now available for 369 usd shipped and listed in the Shops.
    Regards,
    Mirco
    #357 3 months ago
    Quoted from Kerry_Richard:
    Very good points! I just redid my Taxi (decals, then 4 coats of auto-clear), only to have small doughnut sized rings around 2 of the head bolts. I even backed the pressure off those 2 bolts, but donuts would lie down (finger massage them down) and always come back
    I recently bought a brand new cab with MM Rad Cals already installed on it. I noticed the donut raised areas around the hinge bolt holes in the bottom cab and thought it would be a big problem when I drilled the holes for the playfield support brackets (for some reason whoever did the cab didn't drill those). To my pleasant surprise though those four don't have any doughnut rings around them at all. I drilled from the inside out using sharp bits and a pilot hole but they look great even when looking straight down the side of cabinet. I did take care not to over-tighten them but since it's the playfield pivot and support I did make sure they were pretty tight. These decals are really beautiful and pleasant to the touch, if I ever do another cab I'd almost certainly use them again if available.
    #358 3 months ago
    Quoted from Highclasspinball:
    Regards,
    Mirco
    [quoted image][quoted image]
    BSD seems missing from the shop? Are these still available?
    #359 3 months ago
    Quoted from bobukcat:
    @bobukat for clarification to the Pinside Fans...
    I got a few doughnut sized rings around the bolts on my "Decaled cabinet with 4 coats of auto-clear", not on RadCals. I just wanted to be sure there was no misunderstanding. With that said: I do own 4 sets of RadCals and haven't installed them yet.
    Kerry
    #360 3 months ago
    Kerry
    Oh sorry about that and thanks for clearing it up.
    #361 3 months ago
    Bsd is available, i will check the Shops later today...
    Thanks for letting me know!
    Regards,
    Mirco
    1 month later
    #362 79 days ago
    Regards,
    Mirco
    Bump for BSD.
    #363 60 days ago
    Does anybody have pics of a finished Whitewater by chance?
    #364 60 days ago
    Just received a set for my Safe Cracker. Just wanted to check something before i start installation. I have some holes at the front of the cabinet for a lock bar and an alarm key - with normal decals you would fill these first. Can I just stick the Rad Cals over the holes without a problem? Would sure save some time, but I don’t want a sub-par result.
    #365 59 days ago
    Quoted from dluth:
    I'd still fill them. It may be obvious in the reflections otherwise.
    #366 59 days ago
    I would fill them also. Down the road you never know if they will magically appear.
    #367 59 days ago
    I too would fill them and paint the cabinet & head a solid color. Did you see the IJ install where he didn't paint first? You can see the original artwork and he was off about 1/2" from original.
    #368 59 days ago
    Is it advisable to paint solid white or solid black underneath?
    #369 59 days ago
    I'm doing 3 RadCals: Taxi (yellow under) / Indiana Jones (Black) and Bad Cats (Black? / Orange?) not sure yet.
    I don't think you could be wrong with either Black or White. But I'd recommend you seeing those picts of IJ. I just don't know where they are, otherwise I'd repost them.
    #370 59 days ago
    Regards,
    Mirco
    Still hoping to buy a set of these...
    #371 59 days ago
    Quoted from ViperJelly:
    Paint it whatever the background color is. You still need to try and match the front of the head with the radcals.
    #372 57 days ago
    Thinking IJ so it may be black
    #373 57 days ago
    I'm going to paint my IJ all black before installation of RadCals
    #374 52 days ago
    I just picked up an Indy and plan to redo the cabinet artwork. Can anyone explain the pros and cons of rad cals vs regular side art decals? Is one better or worse or easier to do? Which looks better when done, etc? Thanks!
    #375 52 days ago
    Quoted from sbmania:
    Radcals are super easy. No chance of bubbles or wrinkles. You just have to make sure that the cabinet is painted the color of the main background color of the radcal. I'd definitely use them again.
    #376 51 days ago
    I have installed dozens of cabinet decals over the years and if done right, they do require a ton of prep if you want them to look great. I usually clear the cabinet so they go over it like a sheet of glass.
    I have installed 4 sets of Radcals and I still prep the cabinet the same as I do traditional decals so the work is the same.
    However, many folks just slap the radcals over the cabinet without much prep. I would not take the easy way out on this since you can see through the radcals of what is actually underneath.
    Purists will always lean towards traditional decals, however, IF you want a thicker super glossy look, then Radcals are the way to go.
    Applying Radcals aren't as simple as many folks think. You have to route out the holes for the buttons, hinge mounts, etc. and sometimes they are to long and you have to trim or edge to the wood and this can be very tedious and time consuming. With traditional decals, it is much easier to trim these areas out.
    I am glad there are dual options out there for both types of consumers and I found that most of my new clients do like the super glossy thicker Radcals. I do still have a few that prefer the traditional look and want it to look as original as possible too.
    #377 51 days ago
    Lets go Creature from the Black Lagoon Radcals. My machine is ready to back together. Any ETA on the Radcals?
    #378 47 days ago
    I've read a tip that replacing the carriage bolts with elevator bolts (thin, flat head), as an alternative to recessing the carriage bolts for those that place the Rad Cal over the bolt heads.
    Has anyone here tried this? If so, do you still recess the elevator bolts a bit? While the heads are thin, they aren't flush and I fear they'd otherwise cause raised sections in the Rad Cal after application.
    Added 47 days ago:
    EDIT: I've discovered Forstner bits.
    #379 46 days ago
    Quoted from sulli10:
    Let me know on I 500
    Quoted from Gov:
    Another vote for Indy 500.
    Yes... me too, Indy-500
    4th vote for Indy 500!
    #380 46 days ago
    Quoted from Schwaggs:
    Another for i500 please!
    #381 46 days ago
    I would dearly like a set for Corvette! Please make that happen
    #383 45 days ago
    Creech!!!!
    #384 44 days ago
    I have the i500 files, just need to find some time to work on them... ibhave proto and production versions, is there demand for proto? Need to check what the difference ist...
    Regards,
    Mirco
    #385 44 days ago
    Thanks for putting these up in the store.
    #386 44 days ago
    I hope there will be some love for Road Show soon.
    #387 44 days ago
    Quoted from Kevlar51:
    Added 2 days ago: EDIT: I've discovered Forstner bits.
    Did you fill in the cavity between the bolt head and the edge of the cab to make it smooth?
    #388 44 days ago
    Regards,
    Mirco
    Creech update please.
    #389 44 days ago
    No—it wasn’t necessary. Elevator bolts have large flat heads, and if you recess them to be flush with the cabinet, it’s smooth (assuming the hole drilled to recess doesn’t have a significantly larger diameter that the bolt head).
    #390 44 days ago
    Regards,
    Mirco
    I vote for production, not sure what the difference is. Either would look better than my current fade!
    #391 44 days ago
    Regards,
    Mirco
    Whoooo hooo! Thanks!
    Prototype Indy 500 is just red, production has the fade from red to orange.
    Prototype:
    https://www.ipdb.org/showpic.pl?id=2853&picno=74157
    Production:
    https://www.ipdb.org/showpic.pl?id=2853&picno=12063
    I would prefer production.
    #392 44 days ago
    I like the proto
    #393 44 days ago
    Anyone have pictures of the 2 Bride of Pinbot versions?
    #394 42 days ago
    Do we know if (or when) Mousin Around RadCals will be produced?
    #395 41 days ago
    Regards,
    Mirco
    I’d buy a set of either, production version preferred.
    #396 41 days ago
    Yes, i have the files and will have ma soon. Just need some time on the printer which is not easy right now...
    Regards,
    Mirco
    #397 39 days ago
    Regards,
    Mirco
    Awesome! Thanks for the update!
    #398 39 days ago
    Mark down another production i500 set here!
    #399 31 days ago
    When are you gonna run RadCals for SlugFest?
    #400 29 days ago
    Quoted from allsportdvd:
    No love for Corvette???
    Filament Printing
    $ 9.95
    $ 29.95
    COINTAKER.COM
    $ 64.00
    $ 48.00
    $ 22.00
    € 60.00
    Buthamburg
    YouBentMyWookie
    $ 52.00
    Pin Monk
    $ 18.99
    Creo Pinball
    $ 22.00
    $ 12.50
    Gweem's Mods
    $ 11.95
    $ 78.00
    $ 19.25
    The MOD Couple
    $ 84.95
    € 18.95
    Buthamburg
    $ 35.95
    MicksPinball
    $ 5.00
    3D Tech. Pinball Parts
    $ 1,000.00
    $ 130.00
    Pinwize.com
