(Topic ID: 131157)
revenge from mars reed switch issue please help!
By V8haha
9 years ago
  • 25 posts
  • 9 Pinsiders participating
  • Latest reply 4 months ago by Sonic
#1 9 years ago
so my RFM is having issues.
i can't get the Reed switch to work 100% of the time.
it seems to work in the switch check menu but thats if i roll the ball with my hands slowly over the switch
in real game time the switch seems to work 25% of the time.
i noticed that their are 3 total switches for this do all three need to be triggered for the ball lock to start?
someone please help
#2 9 years ago
This is a common problem with rfm . I replaced all my roll over switches with new ones . My Outland switches were the same way , they would register about 33% of the time . Just replace them
#3 9 years ago
but its the Reed switch not a roll over switch.
form what i understand its hard to find new Reed switches.
i did just have to adjust a bunch of roll over switches 6 to be exact but they are all working now.
Its just the magnetic Reed switches that don't seem to be working
#4 9 years ago
Bump anyone have an idea how to fix this
#5 9 years ago
Bump can anyone help me?
I want my game to work 100%
#6 9 years ago
Are the switches tight against the bottom of the insert. If the little rubber guys holding them on have loosened they may not register all the time.
#7 9 years ago
No their all tight against the board. Does anyone know what way their suppose to be installed?
I know they can be flipped around and mounted backwards im not sure what way their suppose to go. Anyone have a photo
#8 9 years ago
Any help? Still not sure what order I the switches should face. I'll post a photo of what mine look like now I've switched the 3rd one upside down
#11 9 years ago
Quoted from V8haha:
I have some pictures when I sent my playfield out for CC. When I get home I will post them.
#12 9 years ago
Steve at The Pinball Resource had a supply of NOS Williams reed switches. Give him a call and see if he still has them available or not. I was able to buy a new one for Cirqus Voltaire a year ago (or so).
Marc
#14 9 years ago
Edit Issue not fixed!
Issue fixed.
So I turned the switches around so that they are the furthest from each other as Posible.
Now it seems to read it every time. Wanted to update everyone in case someone runs into the same problem.
#15 9 years ago
Here is the picture.
#16 9 years ago
ok scratch what i said i didn't fix it.
when i first got the game the ball locked worked no problem. but i have a bunch of roll over switches out. i fixed the switches and then all of a sudden the ball lock didn't work. i didn't think it was related.
now when i moved the reed switches around and started playing it worked 100% noticed after playing there was a credit dot. it was on the roll over switch right behind the reed switches i think its labeled the Center loop roll over switch.
so i just tested it with my finger and got it working not problem. as soon as i did that the ball lock stopped working again.
can anyone explain to me what to do now. is the game thinks that roll over switch is out then the ball lock works. if the roll over is working then the ball lock won't.
#17 9 years ago
Quoted from Crashnburn:
i have all my switchs turned the opposite way. but now i realize the position doesn't matter it has to do with my roll over switch right behind the reed switches
#20 9 years ago
I got the center roll over switch non active again by unhooking the lead now the ball lock works perfect!
So it's something related to that switch.
Anyone have any ideas what I can do?
Is it a board issue?
4 years later
#22 4 years ago
Hey,
sorry to bring back this post from the deads, but i have the exact same problem... this Switch 74 is lazy in play, but works fine when I press it with the finger or roll a ball by hand.
Did you managed to fix it at the end?
I consider, replacing it by a switch like this:
https://www.pinball.center/en/shop/electronics-parts/switches/2244/microswitch-universal-flat-9cm
What do you think?
4 years later
#23 7 months ago
Bump
I have the same issue. Won’t register in game but with finger press or ball rolled over it does
Anyone figure this out?
2 months later
#24 4 months ago
I got strange issues when one diode on the drop target was in the wrong direction. Then one of the opto sensors in the ball through stopped working... It has to do with the matrix setup.
Have you fiddeled with any diodes that you might have turned the wrong way?
#25 4 months ago
Quoted from DK1983:
Bump
I support troubleshooting on the OEM MRS'....just PM and I think I can help you out without having to do much or spending a dime!
Matt
3,600
Coal Valley, IL
4,000 (OBO)
Anderson, SC
3,200 (OBO)
Lancaster, NY
$ 46.99
Lee's Parts
8,000
Grand Rapids, MI
$ 11.95
KAHR.US Circuits
$ 8.99
Inscribed Solutions
$ 85.00
$ 1.00
Pinball Alley
$ 79.00
PinballReplacementParts
$ 84.99
FlyLand Designs
