I recently tried installing an LCD into my RFM and somewhat stupidly plugged the computer into the mains to test the monitor forgetting that the power supply is set to 110v, the fuse in the power supply blew immediately so i replaced it and the machine seemed to be working again however, on putting it all back together again and using the old crt for testing purposes i came across a new problem.
The power board shows a host of blown fuse errors but when i tested the fuses they are all intact. I don't know where to start in diagnosing the fault on this one!
I have added images of the errors as well a picture of the board whilst on.
As you can see there are a number of leds which are not lit. I tried turning on the machine without the computer too but the board leds still are not lit on those fuses.
I also fiddled with the cables and they all seem to be connected firmly.
I cant imagine that the power supply i blew in the computer can cause such an error can it?
Please help!
Thanks in advance...
Mario
