(Topic ID: 139607)
Revenge from Mars computer problems
By dpqrm
  • 9 posts
  • 6 Pinsiders participating
  • Latest reply 4 years ago by julo
PINBALL_Repairing_Williams_Bally_Pinball_2000_Revenge_from_Mars.pdf (PDF preview)
#1 4 years ago
Been working on a nightmare of a disaster rfm that started with no computer. I managed to pick up a used computer along with 2 rom/prism sandwiches. After replacing fan and ps, I have managed to get computer to boot to bios ( with prism card removed) on the bench hooked up to a vga monitor. When I reboot with either prism card I get nada - no signal ( yes I do have a cga-via converter). I find it hard - not impossible - to believe I have 2 bad prism boards. Since I have not had a chance to see a working one in operation I am curious if I am missing something obvious? I have this outside game with no driver board or anything else connected - will this effect PCI boot?
Any suggestions appreciated
#2 4 years ago
Hmmm. Do you need an EGA (not VGA) monitor to display the video from the PRISM card? Anyone remember?
#3 4 years ago
Here is a thread just to make sure you have the wires for conversation properly pinned out, assuming you have a LCD in there and not the CRT being you have the converter.
https://pinside.com/pinball/forum/topic/revenge-from-mars-add-lcd-and-sync-adapter
#4 4 years ago
Thanks for the feedback. I am starting to think that the problem is on the display side rather than the cpu or the prism. I will try to see if I have an cga arcade monitor around or will look at the conver
#5 4 years ago
Sorry - accidental send.....
Converter as I have a second one around.
One other question - does anyone have the slightest idea what the hell the led on the prism card indicates? I have one that is solid on and another card that starts solid then goes out and starts blinking rapidly. I have searched everywhere and can find nothing on what that light indicates.
#6 4 years ago
I don't know what the LED is supposed to indicate, but on my (fully working) machine the LED behaves like your second one. So your first prism card may have some issues.
#7 4 years ago
The one with the solid LED is not booting. The one that goes into rapid blinking may be booting, I'd have to see the LED. Can you post a video?
Nothing else needs to be connected for the computer to boot. If you boot into BIOS, you should boot with the PRISM if it's good.
Rob Anthony
Pinball Classics
http://LockWhenLit.com
Quality Board Work - In Home Service
borygard at gmail dot com
#8 4 years ago
Thanks for the information. Knowing the second card was booting was a huge help as it let me focus on that board. Problem was with the monitor. Once I connected another one I had and got settings correct it showed that it was booting just fine. Appreciate the help - as well as the converter which I picked up from you a couple weeks back.
#9 4 years ago
I've attached some info that may help.
PCB Emporium
$ 279.95
Pin Stadium Pinball LEDs
$ 50.00
$ 399.95
