(Topic ID: 73756)
Revenge from mars add LCD and sync adapter
By newdos
5 years ago
  • 70 posts
  • 26 Pinsiders participating
  • Latest reply 9 months ago by mattosborn
  • Topic is favorited by 75 Pinsiders
There have been 16 images uploaded to this topic. (View topic image gallery).
There are 70 posts in this topic. You are on page 2 of 2.
#51 3 years ago
Quoted from TigerLaw:
Well, my monitor took a crap on Saturday so it's time for me to read up on this switch out. Doesn't seem too terrible.
Awe man....beyond repair?
#52 3 years ago
Quoted from MustangPaul:
Not really sure. Game will power on and play but no monitor. I'd been wanting to install the LCD display anyway.
#54 3 years ago
Quoted from Crashnburn:
Applejuice, will this put 5v on pin 9 on the VGA connection so you do not need a video amp if you are keeping it stock?
Currently that pin is wired as per the original card, though I can add this to future runs if it's something that's wanted.
You can currently choose between original mode and sync converted mode
#55 3 years ago
As long as your tube had a good picture, the chasis can be sent out for repair very reasonably.
When my monitor died (tube bad)... I spent too much trying different LCD panels but was never satisfied as they all put out too much light in their black. Its not something you notice when normally viewing but in P2K excess light up there is very noticeable, for me at least.
In the end I found a new tube monitor and love it.
#56 3 years ago
Hmm, will have to consider the options. Thanks for the suggestions.
2 months later
#57 2 years ago
tiger:
my guess is that you might just need to put a new cap kit in your monitor. do you get any picture at all? or does the monitor make any noise when you power up the machine?
if you're comfortable soldering, then it shouldn't be too much of a problem. I've done about 5-6 now for arcade monitors and this is no different. just make sure that you ground and short out the flyback before working on it (the voltage stored up in those large capacitors is enough to kill you
#58 2 years ago
Quoted from j_m_:
Thanks for the response! It just kind of goes on and off. The game still plays, just with no monitor. Loose connection I'm sure. I've been pretty tied up the last month or so, hope to getting around to this soon.
#59 2 years ago
FWIW The converter pcb will work by itself without a sync dongle added. The old converter with one vga out are the problem pcb's, With this pcb go into menu >> geometry and adjust the v position to like 28 and see if it will sync. The newer converter with 2 vga's out will sync with no issues without the sync adapter too.
#60 2 years ago
Quoted from Brtlkat:
FWIW The converter pcb will work by itself without a sync dongle added. The old converter with one vga out are the problem pcb's, With this pcb go into menu >> geometry and adjust the v position to like 28 and see if it will sync. The newer converter with 2 vga's out will sync with no issues without the sync adapter.
New style pcb
2 years later
#61 10 months ago
This might be a stupid question but why can’t you just plug the lcd monitor straight into the computer with a vga cable?
Thanks in advance
#62 10 months ago
Quoted from mazzaneo:
This will not work because you have to convert the output from CGA to VGA.
#63 10 months ago
Thanks in advance
Because the video resolution out is not compatible with what a modern LCD can understand. Pinball 2000 computers do not output vga natively when the prism is connected
#64 10 months ago
Struggling to find 74ls02 locally, I’ve found 74ls09 and 7402. Can anyone recommend an alternative if any?
Thanks in advance
#65 10 months ago
I guess the question is... can I use the 7402 instead of the 74LS02?
3 weeks later
#66 9 months ago
If anyone is switching to an LCD that has the original WG monitor, I would like to buy the CRT from you. I'm not a fan of LCDs and I have the crappy non-WG monitor in mine. Thanks.
#67 9 months ago
Quoted from robotron911:
Your best bet might be to try to steal one from an arcade game. I’d post a wanted on an arcade forum like klov.com.
#68 9 months ago
Quoted from shirkle:
Thanks. I've looked. The issue is it's a 7300 series monitor, which is not common in arcades. I'm following some leads and I hope to find one.
#69 9 months ago
Sorry, didn’t mean to give misinformation. I believe my SWEp1 has a replacement monitor. From memory, the wiring just needed swapped around a little. I’ll check it later and take a picture if you want. I haven’t looked in the back of that game since giving it a cap kit about 6 years ago.
#70 9 months ago
It doesn’t need to be that model. You can make any 19” standard res color monitor work in there.
$ 44.95
PinBoss Mods
$ 49.95
Pin Stadium Pinball LEDs
$ 67.95
MicksPinball
3,700 (OBO)
Des Moines, IA
3,000 (Firm)
Commack, NY
