(Topic ID: 73756)
Revenge from mars add LCD and sync adapter
By newdos
9 years ago
  • 71 posts
  • 27 Pinsiders participating
  • Latest reply 1 year ago by Thefuge
  • Topic is favorited by 77 Pinsiders
There are 71 posts in this topic. You are on page 1 of 2.
#1 9 years ago
Revenge from Mars LCD fit and how to make sync adapter
Hi all,
I have spent hours looking everywhere for the diagrams to make a sync adapter for my RFM so I can fit an LCD screen. I have finally done it and got it working, so thought I would share it here.
I bought a cheap cga to vga converter off ebay first - shown in the pic. You will then need a vga monitor cable and a 74ls02 chip to convert the H&V sync to a combined sync. I used a Dell 19" LCD computer monitor I had lying around.
First job cut off one end of the VGA cable and strip back the wires. You will need to find the red, green, blue, horizontal sync wire(usually grey) and the vertical sync wire(usually white). All the ground wires can be twisted together. sleeve each of the wires with heatshrink.
Next solder the red, green, blue and ground wires to the respective pins on connector P3 on the board.
Now for the 74ls02 chip. You only need pins 1,2,3,7 and 14. Solder the Horiz sync wire(grey) to pin 2 the vert sync wire(white) to pin 3. Pin 1 is the combined sync ouput and a wire from pin 1 goes to the pin marked 'S' on connector P3. Add a wire to pin 7 for ground and a wire to pin 14 for +5v. This power can be got from within the p2k PC case. Don't forget the board also needs +5v power so just tee together the power leads then off to the pc case for your supply
That's it!!! plug in your new lead to the p2k PC monitor socket and put another lead between the vga socket on the adapter (P4) and your monitor and off you go. Mine worked first time so good luck!!!
Will add more to this when I actually fit it into the RFM.
Feel free to ask any questions.
Kev
#2 9 years ago
Great job Newdos! I'll keep this forum when my monitor takes a crap. Thank You!
#3 9 years ago
No probs tony hope it helps!!
Kev
#4 9 years ago
Quoted from Tony01:
Same here. Added to favorites.
#5 9 years ago
Nice how-to! Will be following this for updates to see how you mount it. Thanks!
#6 9 years ago
for mounting the LCD, you might try this:
Pinball 2000 LCD Mounting Kit
http://www.greatlakesmodular.com/
#7 9 years ago
Well I said I would do it and I have finally got around to fitting a LCD monitor to my RFM, ably aided by my son Matt !!
I fitted a 19" dell monitor which has a supply range of 100-240volt, which is handy as the main supply in the RFM after the transformer is 110volts everywhere.
The pics have all uploaded in a weird order so I have put text next to each pic.
Feel free to ask any questions. I can tell you this looks amazing compared to the old CRT that has some convergence issues !!! I have 2 videos of the old crt and the new LCD - there is no comparison!!! I don't seem to be able to upload them to here so if any wants to see them let me know and I could stick them on you tube.
Cheers Kev (and Matt!!)
This pic below shows the cable mounts screwed back in place with all the cables nice and tidy, the CGA converter screwed to side of cab and the 110v power supply(the old green, white and black lead that powered the old CRT) spliced to the monitor power lead. This means the monitor power works through the main switch under the table as well as everything else.
Pic here shows a quick rough test of everything to make sure all is working before final fix in place(note monitor was upside down at this point!!)
The image below shows how much space is left when finished, without the old CRT in there. As shown by my son Matt round the back of the RFM !!! Only thing left to do now is get a couple of brackets made to mount the fluorescent to light the translate now.
This image shows a pickup of a 5v supply for the cga to vga converter
This shows the monitor fitted in the hole where the old wells gardner monitor came out off. the monitor fitted perfectly and sat in the recess that was already there. You can see I made a wood surrounds and sprayed it black (well my son did!!) before I screwed it into the case. This actually held the monitor in place very tight. We had to remove one of the wood pieces to turn the monitor through 180 degrees (as the image was upside down at first) as it was that tight we couldn't get it out!!
Ok here goes the CRT video first then the LCD one. I don't know why but you are better going to you tube directly to watch these as the res is better
Let me know if they look ok and you can see the difference!!
Cheers Kev
Currently own STTNG, TZ, FT and RFM
Used to own ToM, TAF and Shadow
11 months later
#8 8 years ago
Is that P190St 5:4 or 4:3 (I couldn't find a definitive answer on the web) and does it matter?
#9 8 years ago
Quoted from newdos:
You bet I can see a dif. The lcd is way sharper and I can see the individual stars in the background of the Bally logo. Looks great.
3 weeks later
#10 8 years ago
what is model # of the dell monitor that you used?
#11 8 years ago
mjmmx, I can see P190St on the back.
#12 8 years ago
I try and do as many lcd conversions on arcade games as I can and I have run into sync issues with those. How would I know if I possibly need to add that chip onto one of those games as well? Its generally a since issue that I run into with them not being compatible.
2 months later
#13 8 years ago
Just took out the old and looking for the right monitor to put in , just that the 2 that I have 1 is bulky and might have to take out of frame. Hope to get help as I move along on this project. I love this and have fun learning as I go .
#14 8 years ago
What happens if you use the cga to vga converter without a sync adaptor? I ask because I just got an RFM that has this conversion but the monitor is missing blue. I have a spare cga to vga adaptor that I can hook up but I don't want to break anything.
#15 8 years ago
Just fitted a chip from maplins, same chip but ends with a N.
... No picture should the chip be a P.
Any thought's on a diagnostics.
Many thanks Feaney
#16 8 years ago
its a 4:3 monitor and any 74LS02 should work - check your wiring out
Cheers Kev
#17 8 years ago
Just curious, does the monitor need to be 4:3? I'll be doing this over the next month, since my RFM I just picked up came with what looks like an unsuccessful attempt to install a widescreen 19" VGA monitor.
Great thread newdos!
#18 8 years ago
I've also seen a 22" 16:10 recommended a lot and that is what I have in my game. A 19" 5:3 or 4:3 also seems to be fine.
#19 8 years ago
All,
I picked up a SWE1 in February. I really wanted to convert to a flat panel (my CRT had no green and was mis-aligned) and combining the Horizontal and Vertical sync as described here is an important step - you have to do it if you are going to use the GBS-8200 series up converters.
I latched on to Newdos's combiner in this thread to create a no-solder solution that does this sync combining and provides a simple way to power the new components via USB (the combiner and the GBS-82xx). Steps are pretty simple:
1. install a PCI USB card in your Pinball 2000 computer. This is a pretty simple, plug-n-play addition. No drivers to worry about as the computer can ignore the board; we are just installing it for power. I had to move my prism card over one PCI slot to create space.
2. attach my H+V Sync Combiner board the computer's video card output. It screws on securely.
3. run a USB A to A cable from the USB card to the H+V Sync Combiner for power.
4. run a VGA cable from the H+V Sync Combiner board to the GBS-8200 series up converter.
5. run another VGA cable from the GBS-8200 to the flat panel of your choice (I used a 17" Viewsonic I got at the used computer store for $10)
6. fabricate a panel mount solution and provide AC power to your monitor.
7. turn it on and enjoy.
You can get the board by itself for $25 at my website (http://www.kahr.us). I also offer a kit that contains the PCI card and the USB power cables for $40. Here's what the board looks like:
-Rob
-visit http://www.kahr.us to get my daughterboard that helps fix WPC pinball resets
#20 8 years ago
The GBS converter boards have a header for RGBHV (separate syncs). Why not just make the proper cable?
#21 8 years ago
Quoted from mattosborn:
Didn't try it, but it might work... Crimping JST is challenging but I've had pretty good luck with this tool: http://www.amazon.com/Engineer-PA-09-Micro-Connector-Crimpers/dp/B002AVVO7K/ref=sr_1_1 . You'd still need to power the GBS which I think USB provides a pretty nifty solution.
Or, for the price of the tool you can get the board and all the USB to JST cables. Whatever works for you...
-Rob
-visit http://www.kahr.us to get my daughterboard that helps fix WPC pinball resets or for Williams System 3-7 sound board solutions
#22 8 years ago
Quoted from rkahr:
Didn't try it, but it might work... Crimping JST is challenging but I've had pretty good luck with this tool: amazon.com link »
Crimpers?!?! Why bother? You can buy the JST connectors all wired up for pennies. Let the little Chinese kids do the crimping.
#23 8 years ago
Curious, have you (or anyone else) connected directly to the RGBHV header on the GBS? I like RKahr's solution (less expensive than the http://lockwhenlit.com/CGA.htm option) but going direct might be a cleaner way to go if it works.
Any examples online for a JST cable that could be used?
#24 8 years ago
Quoted from phlegmer:
I've used it successfully for some video games... haven't tried it with a P2K yet. I could wire it up and check.
The 8-pin JST cable actually came with the GBS-8220 board I bought. Looking at eBay, that seems to be the case for most. Example:
ebay.com link: itm
#25 8 years ago
Ahh, cool! So if it comes with the cable, would only need a DB-15 to attach to the other end? I don't have a GBS card yet and it looks like there are 8200's and 8220's in various versions (Version 4 is the latest?). The only difference I have found between the two is that the 8220 has an extra VGA output. I suppose if you wanted to add a second monitor on top of the arcade cap.
#26 8 years ago
Mine only came with the 5 pin connector that does not support separate syncs. The 8 pin might work but when comparing the pic in the listing to the manual it seems that one of the sync wires is missing. Here is the relevant manual page. image.jpgimage.jpgimage.jpgimage.jpg
Buy it, try it, and if it doesn't work, get my combiner. And be sure to share what you learn. But I've only got 11 left and am not sure about making more.
-Rob
-visit me at SFGE to get my daughterboard that helps fix WPC pinball resets or for Williams System 3-7 sound board solutions
#27 8 years ago
Most of the vendors today include the JST connector harness, not the 5 pin "yoke" style connector like they used to in years past. And yes, there are only 2 sync wires while there are 3 holes for sync. I guess that is their way of saving some pennies.
All you do is decide if you want separate positive Vertical and Horizontal sync, or if you want to feed it just composite negative sync. You may have to move one wire. But, you have to make sure you select the proper input channel (RGBS vs. RGBHV).
For most standard Composite Negative Sync applications (Jamma type boards), it is best to feed the sync in through the single wire to S. In the case of P2K, I would assume you will need to use 2 wires and make sure they are populated in the H and V holes of the connector.
#28 8 years ago
Hmm, I tried to make one and my converter is just reporting "no signal". I'll have to check my wiring but I thought I was careful
Update: I had rather stupidly worked out my pins incorrectly. It works now that I've wired it right and fortunately the IC survived having the 5v on the wrong pin.
#29 8 years ago
Anyone give the 8 pin connector a try yet?
#30 8 years ago
I thought about it but I wondered if it was not just the same thing as plugging into the 15 pin VGA socket.
#31 8 years ago
I put in a mouser order last night and one thing I added was an 8 pin JST connector. I'm as curious as the next guy...
I've also got enough stuff to put together 10 additional kits of my H+V Sync Combiner.
-Rob
#32 8 years ago
Awesome, looking forward to the results!
#33 8 years ago
Quoted from insx:
On a model GBS 8220 V3.0, they are indeed the same. In fact, the HS and S pins are connected together and in turn, also connect to the 15 Pin VGA connector. This may not be true of other models or versions.
#34 8 years ago
Has anyone tried these as of yet?
ebay.com link: itm
#35 8 years ago
That's only a break out board. It does not alter the sync signal that is discussed above in the sync combiner/adapters (74LS02) being made.
The trim pots are to tone down the Red, Green, and Blue drive so you don't saturate the colors on an LCD.
#36 8 years ago
Ahh ok thank you. I have seen some of the converter boards with the RGB Pots on them as well I might grab one of those then. Thanks again for your reply, now I have to track down a good 22" LED LCD 16:10 monitor
3 weeks later
#37 8 years ago
Having been fixing a lot of pin2k games over the years and with the issues of the sync conversion my take on the solution was to design a replacement for the pci vga riser card, the one that originally looks like this:
The benefit here is that the extra conversion can be done internally to the computer case and then a regular vga cable can be attached from the modified output to the cga convertor cards video input. Also, I have added some dip switches so that it can be used in original mode to as a direct replacement for the original. I have fixed many games where this riser card is burnt out. (Most likely due to ageing monitors, or people connecting the wrong things to the output)
Price is looking like £25 plus postage. Contact me if you are interested in getting one.
Here's how it looks on the design bench.
pin2k cga to vga pci header layout.pngpin2k cga to vga pci header layout.png
#38 8 years ago
Looks like a nice replacement AppleJuice. How is it powered to do the conversion?
#39 8 years ago
I don't think it does any conversion, I think it just does away with the need to mess around soldering cables.
#40 8 years ago
The board is powered by connecting a standard atx D-type power connector at J3.
#41 8 years ago
Quoted from insx:
The conversion of the sync signals is done on the card via IC1. The output is then ready for direct input into an arcade cga to vga convertor card. It can also be used as a replacement for a bust original by setting the dip switches accordingly.
#42 8 years ago
I'm still confused about the need for 2 conversions but I don't need one so never mind.
3 weeks later
#43 8 years ago
I got my pcb blanks in and am assembling the first batch of riser cards. I will be adding them to my web site store in due course. Contact me if you'd like to get one.
4 weeks later
#44 8 years ago
Now available and added to my store here: http://mypinballs.co.uk/electronics/store.jsp £25 plus postage to your country
cga_sync_adapter_assembled2.jpgcga_sync_adapter_assembled2.jpgcga_sync_adapter_assembled3.jpgcga_sync_adapter_assembled3.jpg
2 months later
#45 8 years ago
Quoted from applejuice:
What's with the dip switches? I looked on your site "more info" but is a blank page. Also I don't remember a cable like J1 crom the original cpu box.
#46 8 years ago
Quoted from splitskull:
The dip switches allow you to set between original mode and lcd mode. J1 is the input connection from the motherboard like the original was. See post 37 for a pic of the original and more details on why I designed it
The more info sections of my site are in the works
9 months later
#47 7 years ago
Any info yet on what the dip switch settings are?
#48 7 years ago
As mentioned there's 2 settings : as an original riser card, or as a sync convertor
Dip Switches are set as follows:
1 & 2 ON - Sync Convertor Mode
1 & 3 ON - Original Compatibility Mode
This is all included in the instructions when you purchase one
1 month later
#49 7 years ago
Well, my monitor took a crap on Saturday so it's time for me to read up on this switch out. Doesn't seem too terrible.
#50 7 years ago
Applejuice, will this put 5v on pin 9 on the VGA connection so you do not need a video amp if you are keeping it stock?
$ 46.99
Lee's Parts
Interactive
Gweem's Mods
Sound/Speakers
4,700
Shelbyville, IN
$ 299.95
Pin Stadium Pinball Mods
Led
$ 399.95
Led
$ 79.00
PinballReplacementParts
$ 649.95
Led
$ 5.95
The Pinball Scientist
Protection
$ 8.99
Inscribed Solutions
Other
KAHR.US Circuits
$ 399.95
Led
This page was printed from https://pinside.com/pinball/forum/topic/revenge-from-mars-add-lcd-and-sync-adapter and we tried optimising it for printing. Some page elements may have been deliberately hidden.
