I am having to rewire a coin door that has most of the wire colors worn off, I am wondering first off what the schematic for the wiring from the bottom board is calling the "tilt switch" is located, and where the "return 0" wire hooks up to to start the chain, to the blue and white daisy chain at the test switch or to the other post on the test switch? Right now I currently have another wire entirely coming from the non daisy chain lug of the switch. I will attach a picture of said test switch situation. Furthermore, on an unrelated note,I have the version of the power supply that has the blue plastic pots, what value should they be tuned to? The schematic says 1kohm but it's the schematic showing the earlier version. I tuned the right hand pot to 1k but cannot get the left to tune to 1k. Only 750ohm, does the left hand pot need to be replaced?? Thanks for any and all help on something I'm sure I'm making more difficult than necessary.
