Quoted from HeyYou:The machinist can drill the hole, but creating a hole with the ridge at the end doesn't seem possible without a mold.
Bore the shaft hole into the knob.
Then drill a small hole in the knob, intersecting the shaft hole.
Tap a roll pin through the small hole.
Now you have a "ridge" at the end of the knob and the shaft can't slip.
(I'd probably put a set screw somewhere near the base of the knob, too)
