So I swapped playfields in this BK basket case 3 years ago.. today I decided to finally get it back together. I am having a few issues.
1) first, in the bottom of the cab there is a harness that comes off the transformer toward the front.. Even if unplugged, the game seems to work.. This supposed to go anywhere? There is a wire cluster that has a dark blue 6 pin molex, a 2 pin molex, and a white 12 pin molex, and a 9 pin long connector with 3 wires in it (grey/green, brown, gry). Again, game 'seems' to work without any of those hooked up. I have a rottendog power supply, and it has a 2-plug connector on it.. however plugging them together makes no dif to my other issues.. not sure if these just sit and remain unconnected?
2) All the playfield lights work and are new. But none of the GI lighting works. In test mode with all lamps on, the still do not work.
3) 2 lights in the backglass flicker.. the ones with wires directly to them. However, none of the others do. In test mode, all the bottom lights in the tubes are one, except the leftmost one. I can put a dmm on the wires set to AC, and see a voltage in the wiring that pulses.. but lights don't come on.
4) I went through the testing and set all switches to be open. On the solenoid test, #8 and 9 do not work. If I meter the wires, there is a voltage to the coil, but it does not pules to fire like the other coils do if I set them to fire continuously. More than likely a transistor?
5) When test mode is on, I leaned against the left flipper button and the flippers went off.. however the right side does not.. should flippers fire in test mode?
6) The game doesn't always boot when turned on.. turning it off, then on again usually works. What would cause this to be so intermittent a problem? With the rottendog power, the issue should not be voltage or power..
