Not meaning to hi-jack this thread or anything, but since I'm also working on a Taxi, thought it makes sense to include questions here:
Someone didn't even bother to CLEAN the playfield before slapping down a huge piece of mylar OVERTOP of dirt, crud, and even SAND as you can see in the photos. I'm thinking about cutting out the mylar around the inserts so I can clean the crud out - the inserts are also slightly raised so i want to soften the glue up around them, and re-glue/re-seat them. After they dry, I'd then re-apply a piece of mylar (unless you think the "spreading crazy glue on top" method works pretty well??). I don't want to tackle taking off all the mylar...............
Also, look at the wire ball guide photo, is this supposed to sit that far down on the pf?? This guide is located above the "all passengers" target on the left-hand side. I think I need to pull it up a bit.
Lastly, look at these posts supporting a plastic piece on the right-hand side beneath the spin-out ramp - it looks like these are not the correct posts - one has a screw hole in the top that isn't used, and one looks like a "bumper" post that usually has a small donut rubber over it???
Nate
