(Topic ID: 231950)
resto: PIN*BOT (mof: 20181205)
By mof
1 year ago
  • 70 posts
  • 11 Pinsiders participating
  • Latest reply 1 year ago by mof
  • Topic is favorited by 12 Pinsiders
There have been 55 images uploaded to this topic. (View topic image gallery).
There are 70 posts in this topic. You are on page 2 of 2.
#51 1 year ago
What is moonwalking?!
#52 1 year ago
When a ball can travel up and out the inlanes (but with enough spin) to then immediately drain into the outlane.
If the posts/rubbers/switches are not adjusted properly on every machine, then this exciting (yet frustratingly comical) action cannot occur.
-mof
#53 1 year ago
I changed some rubbers and cleaned up some start posts. I'll never know how people get the wax that FAR up the start posts...
-mof
#54 1 year ago
Quoted from mof:
Quick check on high priority items that are bugging me. It's coming along!
FIXING SOON (5)
* plunger barely makes the 20,000 up top on the vortex
I think I see the problem in one of your initial photos, you have a standard spring on the shooter rod. Pinbot takes the stronger blue spring #10-148-3.
#55 1 year ago
You have lost a screw behind the flash bulb.
#56 1 year ago
ha !!!
I think I snagged it, I'll have to check again to be sure!
-mof
#57 1 year ago
Weird, I thought I read it was supposed to be a red, so I went with red! Had to cut it back a ways, but it's perfect now.
-mof
I had to cut the red spring back to get the proper tension.
The result? Nailed it!
#58 1 year ago
This came with a broken bracket -- got a new one from Pinball Life -- it is not the same style as on the 1986 games, but it works.
-mof
20181214_pb-bracket-replacement (resized).jpg20181214_pb-removed-bracket (resized).jpg
#59 1 year ago
Quoted from mof:
-mof
[quoted image][quoted image]
You know what's funny about those original System 11 / WPC-era rear glass plastic channels: they're made with holes for the screws, yet every single game that I've taken off the channel to clean it up, every screw missed its hole, every time.
#60 1 year ago
Quoted from jibmums:
missed its hole
I think we've all done that from time to time.
,p
#61 1 year ago
First ever time I removed the translite all the way, and cleaned the glass on *both* sides. Haha. It really helps and makes the colors pop.
And you know what?
"The more you restore, the higher the score..."
-mof
#62 1 year ago
ISSUES (13)
FIXED (12)
* you cannot complete the 5x5 square of inserts to lower the target bank
* there's some ball hop
* I don't like the ball action out of the left ramp, it hits a rubber and bounces laterally
* you cannot moonwalk the inlanes
* I don't like the red plastics for the mini playfield -- saw a friend go clear -- will re-use his treatment
* five colored stripes that lead to the eyes need touch up at the gap
* I want to try out the light baffles that fans have made for the backbox and tighten that up
* broken playfield glass channel
* pops need adjusting (bulb out)
* dirty rubbers -- slow action (of course)
* a few loose posts
FIXING SOON (1)
* PF scrapes inside of cabinet (it's a hinged PF)
#63 1 year ago
before:
This post was not happy
happy post!
#64 1 year ago
Quoted from mof:
before:
happy post!
For the love of God, please make yourself a protector for "big blue" before you smack a ball into it and break off that fragile end near the target bank!
#65 1 year ago
Time to pick something new to work on. Reviewing the master list, I'd say these sound the most interesting:
CABINET
* Apron, and shooter gauge clean it (use a minimal gentle cleaner, don’t remove any paint)
* Lockdown bar receiver, de-rust, clean and reinstall it
* Playfield guides and edges inside the cabinet, clean/wax them for ease of movement
* Coin door/Carriage Bolts -- clean/straighten/paint as needed
HEAD / BACKBOX
* Backglass, add enough foam insulation material on the lamp board and display edges until the backglass cannot move once everything is properly in place. Test your work by rattling the head to simulate good nudging. Remove the tilt bob first, to TEST the system. The pin should be dead quiet when you rattle it.
PLAYFIELD
* Acorns, install new set to match plastics
* Flipper assemblies, molex and rebuild
* Playfield brackets, (that seat in the lockdown bar) tumble and reassemble
* Shooter Lane protector, polish and reinstall
* Wires, inspect EVERY wire termination for breaks/fraying and cut/re-solder as needed
Pretty much the last "playability" thing to work on is rebuilding the flippers -- which is always super fun to do.
-mof
#66 1 year ago
Now that you mention it, I see one end of the eyes plastic is broked -- so perhaps that one deserves a protector -- which one were you thinking of?
I haven't been getting any airballs so far, so I've been kinda low-concern about that...
-mof
#67 1 year ago
Quoted from mof:
-mof
I was thinking about the big blue plastic to the left of the visor that wraps around the alley. The visor really needs a protector, too. Pretty sure I still have an unused CPR visor plastic amongst my stuff if you are looking for a replacement.
#68 1 year ago
can that one take a ring I wonder?
1 month later
#69 1 year ago
My pin*bot sticker came in the mail today, thanks to wombat !
-mof
Gweem's Mods
$ 28.00
$ 54.99
$ 9.00
2,999 (Firm)
Richfield, MI
2,850
Blaine, TN
$ 18.99
