As for the backglass...
* It has wear spots around 2/3/4 and player displays where the glass has rubbed against the BG.
* It has cracks in a few areas that need hairline touchups
* It has nicks here and there that are barely distracting
1. I locked it down with Krylon triple thick 0500, this has many benefits: easy to remove work without hurting the original -- makes it VERY easy to pick up and grab and not worry about ever hurting the art again. I like this.
2. I did some preparation. I reviewed all my acrylic paint to ensure I didn't have any surprises. I decided to treat myself to 8 new tiny brushes. I need to prepare even more -- I need 20+ little containers to store the mixed paint, so I can work on multiple areas at once and add layers of the SAME color when the paint dries.
3. I did some work, and learned a few things:
A. paint pools in different amounts which impacts the opacity.
B. matching paint is tricky
C. you really want to keep your coverage minimal, but you MUST cover the edges. tricky stuff
D. when you finish you want to cover in white. I'm still learning how much and why...
What about airbrushing? -- I am learning towards learning to do this finally. It wouldn't have come in handy much for this project. But I can see the advantage of covering the white this way.
Is this Gorgar a good BG to practice on?
Yes.
This Gorgar is my "cheap find -- try and learn a lot on it" machine, and it's put me to the test in many ways...
So it's very tough for me as an artist to do a "so-so" job while learning something new, but I promise to only practice on examples that have accurate reproductions (like gorgar and firepower) so that I "do no harm" -- also, I'm doing all my work on top of triple thick, so I should be able to wash all this off and start over some day when my skills are at a higher level. Right?
haha... fun times.
-mof
I'll post some before and afters when the work is done-done.
