(Topic ID: 120031)
resto: Gorgar (mof: 20150301)
By mof
9 years ago
  • 177 posts
  • 28 Pinsiders participating
  • Latest reply 6 years ago by metalkatt
  • Topic is favorited by 18 Pinsiders
There are 177 posts in this topic. You are on page 1 of 4.
#1 9 years ago
Today, I lost my soul to Gorgar...
GGOORRGGAARRRR... HHURRRRRRTT...
A good (non-pinhead) friend of mine has been telling me for years that "Gorgar was his childhood favorite," and so I've been on the lookout for an affordable one for <$900 over the last 2 years, and each one that came up had some sort of "issues" I'd have to overcome. Sometimes, just waiting for a local Pinsider to help out pays off...
A local Pinsider sold me his Gorgar to free up some cash/space. It's already been "gone through" and works well. He put a nice sound amp in there and added a small speaker behind the grill as well. I can't wait to hook up the external sub woofer as well. It will sound epic (it already does.) How about those nifty Scared Stiff flipper bats, eh? It wasn't my plan, but the more I play it with them on there, the harder it will be to remove them. It adds fun to the look for sure.
I've already cleaned the PF and waxed it, and logged 30+ games. What a sweet game it is. I had no idea Gorgar was this much fun.
-mof
(PICS are in the next next post.)
EVALUATION:
PARTS/GRADES (6.5) overall
* Apron: 6: has a few scratches that are "character flaws", replacement would be "nice to have"
* Boards: 9: Everything seems to be working. Two new Rottendogs in there, huge bonus
* Body: 5: pretty fair shape. Lots of scratches for now, otherwise good wood, and decent shine. bondo/sanding in the future and repaint/stencil no question.
* Backglass: 6: good restore candidate, otherwise need a new one from Mayfair $$$.
* Displays: 9: nearly perfect
* Inner Cab: 8: Looks very good at first glance
* Legs: 7: Legs are ok, and original
* Plastics: 7: has a decent set on there, I don't think there are too many "see-through" holes. Just small scratches
* Playfield: 6: flat, planked, crazed, good enough to enjoy for years. Very little isolated wear. Wasn't played too much.
* Pop caps: 9: aged white, but 100% intact. Very nice!
* Shooter and Assembly: 7: needs a good polish
* Side Rails: 8: Flat and clean, all nails present. Didn't see any major bumps at first glance
* Transformer: 8: Looks good.
Shopping List ($200 budget, $155 current)
New parts:
* cliffy lane guides $20
* flipper bats $7
* flipper rubbers $3
* flipper switches $10
* 2 new flipper mechs and solenoids $80
* lamp sockets $4
* leg levelers $5
* rubber kit $15
* shooter spring $1
* solenoid sleeves $10
SOMEDAY $850: New BG, Stencils and Cab repaint
#2 9 years ago
TASK LIST
Here's the work required on this baby before I deliver it:
COMPLETE (59.0 hrs)
* Install new leg levelers and floor sliders (.5)
* Legs, set pitch and level (.25)
* Plug, ensure it’s in good shape, or replace (x)
* Playfield, clean and wax (.5)
* Lamp sockets, review that all work properly, and clean/replace any that need it (.50)
* Dipswitches, set them for freeplay, etc and/or set functions using coin door buttons (.25)
* Shooter, ultrasonic, and re-assemble it (.5)
* Reposition both flipper return frames to better score "D" and "E" inlane switches (2)
* Replaced both flipper mechs and upgraded the coils to 28vdc (4)
* Flipper button switches, replace with new parts (.75)
* Flipper buttons, ultrasonic and reinstall (.25)
* Flipper return frames, remove bells, and install new set from Cliffy (1)
* Cabinet, troll it for parts with magnetic wand, and vacuum/clean it out (.5)
* Shooter lane protector, polish and reinstall (.25)
* Backglass, clean both sides carefully (.25)
* Displays, wipe down glass and rubber (.0)
* GI lamp board, remove all bulbs, wash 'em all, and install only 10 (my personal taste) (.5)
* Caps on power board (were already done) (.0)
* Pit plastic, clean it (.0)
* Acorns, install new set to match plastics (.25)
* Ball guides metal walls x 4, polish and re-install (.5)
* Orbit bar, buff and polish (.25)
* Switch test (ensure CPU and Physical switches all register each switch) (.25)
* Ball stop (above saucer), ensure it is polished and clean and reinstalled (.25)
* Posts, tighten, tumble and re-fill all stripped holes (.25)
* Bulbs, install ultrasoniced 44s and a few LEDs where needed (topside) (.25)
* Lockdown bar, de-rust, clean and install new foam (.0)
* Playfield guides and edges inside the cabinet, clean/wax them for ease of movement (.0)
* Plastics, install new ones where needed, and verify you have the supporting hardware (.0)
* Cabinet wires, ensure the 4 harnesses move freely when playfield is rotated up/down (.0)
* Backbox, clean and vacuum it (.25)
* Fixed bad socket (.25)
* Installed 2 new sockets and adjusted wall and starpost (3)
* Drops "GAR" cleaned and reinstalled (1)
* Apron, trough area, and shooter gauge clean it, new sleeve (2)
* Playfield brackets, (that seat in the lockdown bar) tumble and reassemble (.5)
* Added two blue LEDs (.5) to flippers and "cave"
* Ball guides, (wireform) polish x3 (.0)
* Added green LED (.5) to snake pit
* Plastic protector made for "GAR" (1.0)
* "GAR" drops need to reset more frequently after 3rd target drops (.5)
* Backglass, install new grip tape to better hold the backglass to trim (.25)
* Playfield glass channel, polish it (.75)
* Solenoid check, review to ensure they are all to spec, check resistance (.25)
* Switch adjustments (1-2-3 lanes, inlanes, outlanes) (.5)
* Coin door, clean it, replace (.25) plastic (1.75)
* Cabinet sides cleaned and waxed (1)
* Paint pen inside and outside of cabinet, coin door, and head edges (1)
* Legs, de-rust, polish and wax (1) (30)
* Work the GAR drops again until they always reset (1)
* Fuses, review and replace to spec (.5)
* Fuses, review recommended upgrades to improve safety (1.5)
* HV Driver Board rebuilt (2/3 complete) (1)
* Coin door carriage bolts, remove and clean and polish them (2)
* Plastics, clean and flatten (1)
* Lockdown bar receiver, de-rust, clean and reinstall it (3)
* Coin door flap, remove and de-rust it (1)
* Flipper nails re-install and dremel off bottom-side (2)
* Drops, try to make them work well again (1)
* Leveled insert (1)
* install red start button (2)
* de-ruse, clean, and reassemble lamp door brackets (1)
* triple-thick and touch up backglass (4)
* create new instruction cards that are more clear (3)
* replace J2 connector, and sand/clean contacts (1)
* shaved spacers in backbox so displays lay more flat, added foam to protect backglass (1)
* Power, check all board Test Point’s (TPs) against spec (.5)
* Set up clean "away" coin box with extra fuse set, extra bulbs, documentation, etc. (.5)
* replace resistors for flashers: https://pinside.com/pinball/forum/topic/firepower-tech-repair-and-restore#post-2276980 (.5) 57.5
* Final touch ups on backglass (1.5)
#3 9 years ago
Pics!
-mof
201503_Gor_-backglass.jpg201503_Gor_-backglass.jpg201503_Gor_1-2-3-lane2.jpg201503_Gor_1-2-3-lane2.jpg201503_Gor_1-2-3-lanes.jpg201503_Gor_1-2-3-lanes.jpg201503_Gor_apron-close-C.jpg201503_Gor_apron-close-C.jpg201503_Gor_apron-close-L.jpg201503_Gor_apron-close-L.jpg201503_Gor_apron-close-R.jpg201503_Gor_apron-close-R.jpg201503_Gor_apron.jpg201503_Gor_apron.jpg201503_Gor_backglass-cracks.jpg201503_Gor_backglass-cracks.jpg201503_Gor_cab-marks.jpg201503_Gor_cab-marks.jpg201503_Gor_cab-wear.jpg201503_Gor_cab-wear.jpg201503_Gor_cab-wear2.jpg201503_Gor_cab-wear2.jpg201503_Gor_cracks2.jpg201503_Gor_cracks2.jpg201503_Gor_flipper-close-up.jpg201503_Gor_flipper-close-up.jpg201503_Gor_flipper-reverse.jpg201503_Gor_flipper-reverse.jpg201503_Gor_flipper-view.jpg201503_Gor_flipper-view.jpg201503_Gor_head-flaws.jpg201503_Gor_head-flaws.jpg201503_Gor_head-rear.jpg201503_Gor_head-rear.jpg201503_Gor_head-rear2.jpg201503_Gor_head-rear2.jpg201503_Gor_head-top-dry.jpg201503_Gor_head-top-dry.jpg201503_Gor_inlane-L.jpg201503_Gor_inlane-L.jpg201503_Gor_inlane-R.jpg201503_Gor_inlane-R.jpg201503_Gor_inside-2.jpg201503_Gor_inside-2.jpg201503_Gor_inside.jpg201503_Gor_inside.jpg201503_Gor_inside3.jpg201503_Gor_inside3.jpg201503_Gor_lower-pf.jpg201503_Gor_lower-pf.jpg201503_Gor_night-shot1.jpg201503_Gor_night-shot1.jpg201503_Gor_ok-coin-door.jpg201503_Gor_ok-coin-door.jpg201503_Gor_oops-resistor.jpg201503_Gor_oops-resistor.jpg201503_Gor_playfied2.jpg201503_Gor_playfied2.jpg201503_Gor_playfield.jpg201503_Gor_playfield.jpg201503_Gor_pop-wear-none.jpg201503_Gor_pop-wear-none.jpg201503_Gor_pop-wear-spot.jpg201503_Gor_pop-wear-spot.jpg201503_Gor_Saucer.jpg201503_Gor_Saucer.jpg201503_Gor_Shooter.jpg201503_Gor_Shooter.jpg201503_Gor_SNAKE.jpg201503_Gor_SNAKE.jpg
#4 9 years ago
Well done MOF, glad you finally got it. I kinda like the Scared Stiff bats as well. Not going to lie, I always thought this game was kinda a snooze, looking forward to whan you get it dialed in to the level that you approve of and come over and play some serious games on it so it can change my mind.
#5 9 years ago
Quoted from practicalsteve:
Well done MOF, glad you finally got it. I kinda like the Scared Stiff bats as well. Not going to lie, I always thought this game was kinda a snooze, looking forward to when you get it dialed in to the level that you approve of and come over and play some serious games on it so it can change my mind.
Thanks man. I've only played it a few times at PPM (where you can never enjoy the sounds), and it never "wowed" me there either. It won't play like my "blue edition (tm) High Speed", but I'll make sure it feels great.
-mof
#6 9 years ago
Its easy sending games your way becuawse I know they are getting the MOF treatment. Lay him down at the land of the 80s pins.
Its definitely not a perfect example but im glad it could work out for you. Hopefully your buddy understands the gift he is going to be given. Most importantly I hope everyone enjoys the hell out of it.
#7 9 years ago
I love my gorgar! Glad to see other people enjoying it also. Be sure to screw the back leg levelers all the way out to get the most enjoyment out of it.
#8 9 years ago
Quoted from Fast-Ed:
No doubt -- I always try for 6.5' and usually get all my games past 5.5', depending on the floor location.
-mof
#9 9 years ago
Grinding right down the list (in random order)
All bulbs working -- always thankful when the lamp matrix is happy.
There are a few old/corroded sockets that may deserve a replacement some day.
-mof
#10 9 years ago
Gorgar rules! Do we have a club yet?
#12 9 years ago
Hell ain't a bad place to be, eh Mof? Nice score. Gorgar kicks ass! i can only imagine how great it will sound with an external sub.
#13 9 years ago
Shooter assembly polished, ultrasoniced, new sleeve, check.
-mof
#14 9 years ago
Nice. I love all the shiny stuff I was way too lazy to do haha.
#15 9 years ago
I was getting fed up with how I could not score the "D" or "E" inlane switches from a ball with momentum moving back up into the lane from the flippers.
I had never in my life seen a pinball machine where the flipper return frames were placed in completely the wrong location.
The location of these frames made the ball travel so bad, that with "ANY" force weak or strong, I could NEVER get the ball to score from the inlanes (going up). This meant the "back door" way to score the 1-2-3-4 lanes could never be had with an alley pass or ball trap.
-mof
#16 9 years ago
I then had to fill all 6 holes with super glue and bamboo toothpicks, and pack them good -- especially the middle ones -- since I would be drilling up against that middle hole in a few minutes. I let that sit for 15 minutes and then came back to win the fight.
I then took the NEW:
"Enhanced Gorgar flipper return frames" from Cliffy, and measured using it, starting with the ideal location for the inner (of the 3) bells. I took a poker, and pushed down and made my "starter" hole. I then took a flashlight, and shined it in there to ensure I had the hole in the right place. I did. I then drilled with a 3/32" drill bit, and then I set up the hole with by screwing in a hex screw to get all the threads started. Once complete I screwed in the screw for the first bell. Next, with one bell complete, I aimed the curved end of the frame to the best position on the "inside" of the ball guide, and then poked my hole. I was off a little when I checked it with the light for best "middle" position, so I dug another hole just next to it and dug between the two -- drilled it, and screwed in the second screw. Now the third one was easy, since the frame was holding itself in place for me. I poked, removed the 2 screws and frame, and then started the hole with the hex screw. I then screwed all 3 screws back into place and then play-tested it.
I took a pause, and bent the switches a little bit to get the switches to lay a hair lower in the switch, to enable easier pass-through of the ball. I also took some 400 grit, and shined up the switch a little. (Repeated on both sides)
I repeated steps for the other side.
Now I can score on an alley pass from either side, and I score many more D's and E's when trapping a fast-ball. This is how it should play.
Success!
-mof
You can see how far off the original frames were from where I decided to put mine. I only had 1 NEW Gorgar prototype from Cliffy, so I decided not to install it. I re-installed the old ones instead, which had very little wear on them, but I very much look forward to the newer set with 1mm more height and a few mm more material covering the "hinge" of the flipper.
201503-Gor-return-frames-good-both.jpg201503-Gor-return-frames-good-both.jpg201503-Gor-return-frames-good-L.jpg201503-Gor-return-frames-good-L.jpg201503-Gor-return-frames-good-R.jpg201503-Gor-return-frames-good-R.jpg
#17 9 years ago
And once again my favorite pinball proverb comes true:
"The more you restore, the higher the score" (tm)
-mof
Just got my first ever free ball on Gorgar with 345,000. F I N A L L Y...
#18 9 years ago
Does the ball move smooth to the flipper? I hate when the ball hops to the flipper.
#19 9 years ago
Yes, it's even better with the new enhanced return frames with the extra 1mm on there.
-mof
#20 9 years ago
I've always thought I might like Gorgar in the same way I love Sorcerer. Seems like a simple, quick, punishing game like Sorcerer. If I had room, I'd try to pick one up.
Quoted from mof:
Hey, that's not supposed to be there
...but I've got the same one on my desk! It's a nice little amp.
#21 9 years ago
Tonight was a triumphant night. 4 hours on the flipper assemblies -- best 4 hours of the entire shop job.
The grody-to-the-max original flipper assemblies were removed and put in a coffin.
New mechs were installed, and they worked like a charm immediately after install.
1. I did have to remove both plastic clips that keep the wires in place.
2. I invented new orientations for both brackets and just started using hex screws (2) to install each assembly (before I install another 6 each)
Game now plays like funnn smash-mouth 1979 pinball should feel.
-mof
Here are the pics...
OLD
NEW PARTS
NEW
201503_Gor_new-coil1.jpg201503_Gor_new-coil1.jpg201503_Gor_new-coil2-installed.jpg201503_Gor_new-coil2-installed.jpg201503_Gor_both-new-installed.jpg201503_Gor_both-new-installed.jpg
HAVE FUN!
#22 9 years ago
Worth the cost for the upgraded flippers??? Also have you added additional fuses with the upgrade?
#23 9 years ago
Cool! That's what I'd like to do with my gorgar. I put all new stock flippers in mine but they still seem to push the ball. Where did you get them? What do I ask for? I can't wait to play Gorgar with some real flippers.
#24 9 years ago
You can order the kits pre-made from Terry at PBL. That's the best route.
I recommend being ready to go with molex'ing as well. (That way you don't have to remove the PF, or practice "vertical soldering", and most important -- you can easily remove the assembly some day for inspection/cleaning)
With Terry's site you simply order the L and R brackets and the whole assembly, then there's a drop-down menu for the correct coil, and then you EMAIL him that you want a specific switch type on there instead.
Also, there's a drop down menu for the coil stop. I am pretty sure I have been going with all: 12111 on all my solid states and system 11s.
https://pinside.com/pinball/forum/topic/system-11-club/page/6#post-1019065
http://www.pinballlife.com/index.php?p=product&id=172
The coils should be: Williams SFL-19-400/30-750 Flipper Coil
Coil stop: 12111
Note: There is an extra set of steps when doing a flipper assembly upgrade on a 1979 machine.
See this post:
https://pinside.com/pinball/forum/topic/resto-gorgar-mof-20150301/page/3#post-2484072
-mof
#25 9 years ago
Quoted from nasco62:
Worth the cost? No question.
I've done new flippers/assemblies/mech upgrades on all of my pins. It's the first thing I upgrade, and the most rewarding thing to improve.
-mof
#26 9 years ago
When you combine:
1. new flippers
with
2. new enhanced flipper return frames (also re-aligning them within the game)
with
3. well-aligned inlane switches that allow the ball to travel in both directions smoothly over the switch
you now have a really nicely playing game. I like trapping a fast ball that then rolls through the inlane and flies up through the switch (D or E) and BACK up into the playfield, then back down into the inlane (scoring D or E twice) and then back into the flippers. If your Gorgar doesn't do that (like most of my 80's Williams pins can do), I'd consider upgrading your pin to do so.
-mof
#27 9 years ago
Tonight I need to clean out the cabinet flipper buttons in the ultrasonic, and replace the flipper button switches. Then we'll be really rocking and rolling here.
-mof
#28 9 years ago
Shazzam!
(1 quick hour)
Someone beat me to the punch, and the flipper buttons were already clean.
I tell you what, there is no better feeling than brand new flipper button switches, set up perfectly.
Here are the pics of before and after...
-mof
OLD
201503_Gor_olf-flipper-switch1.jpg201503_Gor_olf-flipper-switch1.jpg201503_Gor_olf-flipper-switch2.jpg201503_Gor_olf-flipper-switch2.jpg
NEW
201503_Gor_olf-flipper-switch-new1.jpg201503_Gor_olf-flipper-switch-new1.jpg201503_Gor_olf-flipper-switch-new2.jpg201503_Gor_olf-flipper-switch-new2.jpg
GOOD GAPS / PARALLEL SWITCH LEAVES
201503_Gor_olf-flipper-switch-gap-good1.jpg201503_Gor_olf-flipper-switch-gap-good1.jpg201503_Gor_olf-flipper-switch-gap-good2.jpg201503_Gor_olf-flipper-switch-gap-good2.jpg
#29 9 years ago
Looks great Mof,
Must be a real blast to play, Haven't got the courage to do it to mine, Would have to try out yours 1st.
#30 9 years ago
Quoted from skywalker:
Looks great Mof,
TY man...
I'll take a movie when I'm done so you can see the play action for yourself.
-mof
#31 9 years ago
Cabinet was actually pretty clean. Now it's all cleaned up. Makes it much easier to find screws when they fall.
-mof
#32 9 years ago
I bet this bad boy is playing quite nice by now. I'm glad you are putting your touches on it. Your buddy is getting a great gift.
#33 9 years ago
Quoted from Jabbles180:
-mof
#34 9 years ago
Trough kickout plate (or whatever it's called) all polished up, and the screws too.
(15 minutes)
100 baby steps, and we'll be there! Dang it sure is a pleasure to work on a 1979 machine. Easiest game I've ever worked on.
-mof
#35 9 years ago
can't wait to play this
nice work MOF!
#36 9 years ago
Quoted from genex:
nice work MOF!
TY,
Look forward to seeing you enjoy it.
-mof
#37 9 years ago
(1 hour)
Pulled ALL bulbs from backbox, rinsed all bulbs in water for a few seconds, dried 'em off by hand, threw out the 20 that were bad, and re-installed ONLY 44's in the controlled lamps around the perimeter, and put TEN 47s where "GORGAR" and the lovely lady are. Rest is bulb-less. My #1 goal is limited glare on the PF, since it's for home use.
-mof
"The more you restore, the higher the score..." (c) mof 2015.
#38 9 years ago
Quoted from mof:
-mof
What kind of sound set up do you have in it?
#39 9 years ago
Previous owner put a pre-amp in, and then included a new speaker and then put a small speaker up top in the backbox to push some high end ut up there. Also has ports and wires ready for an external sub (can't wait to try that)
-mof
#40 9 years ago
She's REALLY starting to play like a gem.
I removed both ball gates. I like the challenge of not getting all the "easy" 2x 3x bonus multipliers now. AND when you rip the lit spinner, it coughs it right back at you, without adding tons of bonus, which dares you to strike again. This puts more points on the spinner, and less on the bonus. I like that.
Rusty gates...
-mof
#41 9 years ago
* Bulbs, install ultra-soniced 44s and a few LEDs where needed (topside) (.25)
* fixed a broken lamp socket (.25)
* installed a missing T-nut (.25)
Enjoy the pics!
-mof
DIRTY ACORNS
DULL METAL
BLOWN SOCKET
LOOSE POSTS
MISSING T-NUT
#42 9 years ago
Can't see in this pic... trying RED colorbombing the 1-2-3 lane plastics. It's ok... We'll see.
Playing really sharp, can't wait to take a vid of the action...
-mof
#43 9 years ago
I see those infamous upside down switch blades in your missing t-nut photo.
#44 9 years ago
Quoted from mwsmith:
LOL !!! WTF is going on there, haha nice catch !
Is that from factory?
-mof
#45 9 years ago
Quoted from mof:
Yep. Most early Williams solid states through system 7 have this issue. One blade was installed wrong. You can take them apart and flip it, but the other contact will have been hammered by the rough backside of that reversed blade and it will eventually become unreliable due to the gold plating being damaged. At least one new contact will have to be installed to have a reliable switch. I've been rebuilding mine as they become to contrary with blades and contacts from Pinball Resource.
#46 9 years ago
I'm pretty sure these are working properly in both directions. I'm all for being prepared and having 2 new switches ready. Can you link the ones you like?
-mof
#47 9 years ago
Common switch parts section near bottom of page. I use the medium blades for roll-over switches and scoring switches with the SM-X contacts. I mash the contact to the blade using a small vise with a piece of hard plastic covering one jaw to protect the face of the new contact.
http://pbresource.com/pfswitch.htm#common
#48 9 years ago
If you really want to get fancy and eliminate maintenance you can do the microswitch upgrade found here: https://pinside.com/pinball/forum/topic/guide-upgrading-early-ss-rollover-switches-to-microswitches
I did this to my System 6 game and it works great. You may have to adjust the bends of the metal wire a bit but once set they work well.
#49 9 years ago
Put in a few fun hours tonight. I had a few problems that were bugging me:
1. The "cave" on the left, has a starpost that sticks WAY out, when a slow-roll comes back out, the ball bounces off that in a very unsexy way.
2. The "cave" left wall is too far off the paint, and should line right up with the edge of the starpost.
3. The "cave" should have more light on the right edge
4. The "cliff" on the other side should have more light
Got my drill and vacuum ready and got to work...
-mof
#50 9 years ago
1. Moved starpost back.
2. Moved the wall out.
-mof
Starpost sticks out:
Wall moved out:
Checking alignment for perfection:
201503_Gor-starpost-rubber-equals-wall-edge.jpg201503_Gor-starpost-rubber-equals-wall-edge.jpg201503_Gor-starpost-rubber-equals-wall-edge2.jpg201503_Gor-starpost-rubber-equals-wall-edge2.jpg
$ 170.00
Displays
Digipinball Shop
Tools
Pincoder Store
$ 69.00
Pinball Pimp
$ 69.00
Pinball Pimp
Newcastle, OK
$ 859.00
$ 27.95
Playfield - Plastics
The Pinball Scientist
$ 129.00
Cabinet Parts
Bob's Pinball Stuff
$ 40.00
The Flipper Room
$ 42.95
$ 1.29
Daddio's 3D Printed Mods
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/resto-gorgar-mof-20150301 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
