Like an idiot, I'm going to skip the post-purchase checklist, and ASSUME my friend had this thing in a good place.
https://pinside.com/pinball/forum/topic/post-purchase-checklist
But, I am going to start the master shop job checklist, and move these items around each day...
https://pinside.com/pinball/forum/topic/shop-job-master-checklist
Here we go!
CABINET (15-20 hrs)
* Cabinet protectors, Install the metal PBL ones
* Cabinet, clean and wax
* Cabinet wires, clean them for appearance
* Coin door carriage bolts, remove and clean or polish them
* Coin door flap, remove and de-rust it (if stainless steel)
* Inserts, ensure they are all flat. Adjust and re-glue any that are not
* Leg bolts, polish and reinstall
* Legs, de-rust, polish and wax. Install new leg levelers and floor sliders
* Power, check all board Test Point’s (TPs) against spec
* Power switch, clean it and the bracket
* Speaker panel trim, clean and polish it
* Transformer board, remove and clean under it if possible, (sand and varnish if possible)
* Transformer brackets, ultrasonic and reassemble, clean up transformer
HEAD / BACKBOX (10-15 hrs)
* Backbox, clean the lamp board, tumble and reassemble door brackets
* Backglass, install new grip tape to better hold the backglass channel and trim
* Backglass channel, (if stainless steel) polish, clean or replace
* Battery pack, install remote one
* Connectors, check all connectors for burn, and replace connectors where needed
* Displays, review displays for proper rubber gaskets and replace with strips of weather insulation to ensure the glass cannot touch the displays, either in game, or in transport
* Fuses, review and replace to spec
* Fuses, review recommended upgrades to improve safety and add a few if advised
* GI lamp board, get it to proper level and height so the displays line up properly through the backglass
* Grounding mods, study what can help the integrity of the machine, and perform them
* Power board, replace 30 year old caps
* Solder joints, check all boards for cold solder joints and reflow as needed
PLAYFIELD (15-30 hrs)
* Acorns, install new set to match plastics
* Drop target assemblies, molex, ultrasonic and reassemble
* Inlane switches -- ensure max moonwalking, and no ball trapping
* Instruction card -- update with rules, and replay score card
* Posts, tighten, tumble and re-fill all stripped holes
* Posts, Ensure all posts are in the correct spot with healthy screws. Unscrew/screw them all back in
* Rubber kit, install new one
* Solenoid sleeves, review them all, and clean or replace them
* Spinner, paint strip it, spray paint it, bake on the paint, and reassemble it
* Star posts, clean and wax, and reinstall
DONE FOR ME (12.0)
* Switch test (ensure CPU and Physical switches all register each switch)
* Switch adjustments (1-2-3 lanes, inlanes, outlanes) (.5)
* Plug, ensure it’s in good shape (0)
* Switch test (ensure CPU and Physical switches all register each switch) (.5)
* Lamp sockets, review that all work properly, and clean/replace any that need it (1)
* Flipper button switches, replaced with new parts (1)
* Flippers rebuilt (4)
* Solenoid test (.5)
* Display test (.5)
* Install new leg levelers (.5)
* Solenoid test
* Plug, ensure it’s in good shape, or replace
* Display test
DONE (31.5)
* Legs, set pitch and level (.5)
* Cabinet, troll it for parts with magnetic wand, and vacuum/clean it out (0)
* Cabinet wires, ensure the 4 harnesses move freely when playfield is rotated up/down (0)
* acetate covers for the instruction cards (0)
* GI lamp board, remove all bulbs, and install only 10 (my personal taste) (.5)
* Dipswitches, set them for freeplay, etc and/or set functions using coin door buttons (.5)
* Flipper buttons, ultrasonic and reinstall (.5)
* Displays, review displays for proper rubber gaskets and replace with strips of weather insulation to ensure the glass cannot touch the displays, either in game, or in transport (.5)
* Stationary targets, ensure they have good foam behind them, clean, and adjust them (1)
* Slings, tune properly (.5)
* Go full LEDs -- minus the slings and flipper return frames (I don't like flicker down there) (.5)
* Flipper assemblies, molex and adjust (3)
* Flipper return frames, remove bells, and install new set from Cliffy, align for perfect ball flow (in both directions, this could require filling and drilling new holes) (1)
* Choose best pop cap color (1)
* Lamp (controlled) test - Fix controlled lamp issue (1)
* Treasure Cove mylar on Playfield, clean and wax (1)
* Replace flipper bats for best color and adjust (1)
* Unwind saucer coil to make it stronger (1) (twice)
* Ball stops (above saucers), ensure they are polished and clean and reinstalled, add a light, change out plastic (1)
* Plastics, clean and flatten (1)
* Plastic protectors, create new ones from scratch for vulnerable high use areas (1)
* Review any shots that send balls at the flippers, and adjust alignments as necessary (1)
* Shooter, ultrasonic, and re-install; replace 1" spring if needed to keep tip from scraping against PF (.5)
* Coin door, clean it (clean up old stickers if needed) (.5)
* Lockdown bar receiver, de-rust, clean and reinstall it (1.5)
* Lockdown bar, de-rust, clean and install new foam (.5)
* Playfield brackets, (that seat in the lockdown bar) tumble and reassemble (1)
* Make new stickers !!! (2.5)
* Pops, rebuild all three and adjust all leaves to hair-trigger perfection, install new skirts and lamp sockets (2.5)
* Wires, inspect EVERY wire termination for breaks/fraying and cut/re-solder as needed
* Slam Tilt (put rubber around for home use)
* Coin door, check wiring and make sure it's all zip-tied away from colliding with the lockdown bar arm
* Paint pen black on inside and outside of cabinet, coin door, and head edges to clean up the look (.5)
* Backglass, clean both sides carefully
* Install solenoid saver board from weebly (.5)
* Plastics, install new ones where needed, and verify you have the supporting hardware (correct posts, etc)
* screws on blue buttons (.5)
* Apron, trough, and shooter gauge clean 'em (use a minimal gentle cleaner, don’t remove any paint -- install new sleeve) (1)
* Backbox, clean and vacuum it
* Playfield guides and edges inside the cabinet, clean/wax them for ease of movement (.5)
* Felt side of cabinet, front of cabinet (.5)
* Playfield glass channel, polish it (1) - (30)
* add foam to the dispays and high points on the light panel to lock in the backglass - (.5)
* Displays, wipe down glass and rubber
* Blue insert bulbs (.5)
* Shooter Lane protector, polish and reinstall (.5)
