Hello all,
I could really use your help. Been spinning my wheels on this for the better part of a day.
Condition
- Game constantly resets when J1 is connecting Power Driver Board to CPU/Sound Board
- Does not reset when J1 is removed
- Power driver board LED 204 blinks non stop
- CPU board LED 200 goes on for a moment and then turns off
- Game behavior is intermittent, sometimes audio plays for a moment, sometimes the display shows for a moment. Most of the time the - display and audio do not function and play field lights blink
Testing done
- Keeping J1 connected and removing all other cables (including display) from the CPU board besides power and J1 still results in reseting
- 5v power readings at CN2 connector was reading 5.25v, I reduced the R115 pot till 5.06v readings on the power board at R114 and 5.00v readings on the cpu 5v measure point
- Wall voltage is at 121 AC
- Tested the ground and ensured all screws on all boards are secure
- Swapped U212 (MS6264A) out with a RAM chip from a Monopoly
- Reseated the EPROM (U210) and CMOS RAM (U212)
- Switched out the J1 cable with a known good one and no change
- Tested all fusses
- Swapped entire power drive board with a known good one in a Monopoly. Resulted in same behavior but the rate of 204 blinking was faster
I dont know what to do for troubleshooting. It seems clear the problem is with the CPU/Sound board but I do not know how to test that. pinwiki.com and the manual dont provide a lot of guidance on testing the CPU board. Does anyone have a whitestar CPU/Sound testing guide or something to that effect?
