Hi gang. Noob here. I have a 1974 Bally Champ. 1000 point targets aren't registering; no chime, no score wheel movement. 1up 1000 score relay heating up. Traced issue to 1000 point relay not de-energizing. Traced that issue back to the Reset relay. That too is not de-energizing along with one of the chime solenoid (which fire at start up). When you lightly press or wiggle the switch plate on the Reset relay, all stuck relays de-energize & the 1000 score wheel advances.
Is this just a bad Reset relay or could there be another issue causing it to not de-energize?
Any repair suggestions?
