New! Dark mode!
(Topic ID: 230716)
Rescue 911 voltage issue
By whizz
2 years ago
  • 17 posts
  • 4 Pinsiders participating
  • Latest reply 2 years ago by whizz
#1 2 years ago
All voltages at the transformer panel are correct at the transformer panel when fuses f4 thru f11 are removed,so I think my transformer is good.I have replaced both caps and all 3 bridges.When fuse f7 is put back in I am getting 69vdc to my coils.My schematic shows it should be 48vdc.The game did play but now it just has GI.Will not go into attract.I can't understand how 50vac to the bridge puts out 69vdc.I have looked at all wiring and don't see anything odd.There are no hacks on any wiring.Does anybody have any ideas.Thanks
#2 2 years ago
Quoted from whizz:
This will be perfectly normal. The voltage is not regulated and therefore it will sit higher than the specified value.
Read up on it at many sites - one here:
http://www.bristolwatch.com/ele/basic_ac_rectification.htm
#3 2 years ago
Before I changed the bridges I only read 29vdc.I am sure the wires are correct.Same part # bridges.
#4 2 years ago
That seems about right. incoming a/c times ~1.4 = 70 vdc
#5 2 years ago
Quoted from whizz:
Maybe the original bridges were faulty? In any case, as OCD_pinball above also suggests, this is about right.
Your problems are likely to be elsewhere.
#6 2 years ago
So is the schematic wrong.It shows the voltage should be 48vdc.
#7 2 years ago
What are your 5 volt readings at on your small power supply?
#8 2 years ago
Quoted from whizz:
The schematic is likely correct. This voltage is a 'nominal' voltage on the schematic. Unless you are trained in electronics you won't understand this that's why I linked to a site so you could learn about it.
#9 2 years ago
I will double check my 5v.yesterday it was 5.1.I have experience in electricity,little in electronics.Thanks
#10 2 years ago
My 5v output is steady 5.2v.My display has part of bottom line out.I have ordered a new one,but while checking found previous owner had installed 10amp fuse.Schematic says it should be 3/8 amp.Could display cause this type of problem?Thanks
#11 2 years ago
Quoted from whizz:
Yes....sort of... Your display driver and CPU board need to boot and talk together for the rest of the machine to work. 5.2 is a little high, but not out of spec. You said the game worked before? If it worked before, why did you change out components, or what were the problems with the game previously?
Do the red lights on the cpu and the display driver board above it flash, or are they solid?
#12 2 years ago
I changed the components when I had the transformer panel out to clean it and install new power cord.The game was real dirty in the cabinet.I did not want it in the house that dirty.Thanks
#13 2 years ago
All the boards flash.
#14 2 years ago
Do you get two audible beeps when you power on the machine?
If not, Lets try this...since it was working before.....
Turn game off.... Remove top connector from the small power supply board. Put a meter on the output of that board and then power game on (With meter connected to output). Adjust the trim/pot on that board until you get your meter to read at 5.0 or just slightly above it (not up to 5.1 though).
Then, turn game off, remove meter, put connector back on, and then turn game on.
These games are really picky about their 5 volt. Replacing the big caps may have given it enough juice to be slightly out of spec.
#15 2 years ago
Ok,That worked.I trimmed the voltage to 5v.The game powered back up and plays again.I seem to have an issue with C relay.I am going to check it out.Thanks
#16 2 years ago
Quoted from whizz:
Cool... congrats... if you need any other help, just post it...
#17 2 years ago
Thanks,I appreciate all the effort.
2,250 (OBO)
Orion Charter Township, MI
2,250 (OBO)
Sycamore, IL
$ 42.00
$ 249.00
$ 50.00
$ 12.50
Gweem's Mods
$ 9.99
$ 5.00
Chrome Candy
$ 90.00
Lighting - Under Cabinet
$ 9.99
$ 130.00
Rods Mods
YouBentMyWookie
$ 1.00
Various Other Swag
$ 165.00
Pixels Arcade Games
$ 27.99
