(Topic ID: 292715)
Rescue 911 Looping Audio
By DigitalJedi084
2 years ago
  • 24 posts
  • 4 Pinsiders participating
  • Latest reply 2 years ago by chad
#1 2 years ago
Hey Guys-
I've been trying to troubleshoot a looping audio issue on a new-to-me Rescue 911. I'm running in circles trying to diagnose things, so I figured I'd ask here. When in the Baby or Flood mode, the dispatcher will continuously say "Please remain calm sir" (ironic right). Sometimes this even continues onto the post game where the "match" is being done.
*I've run all the diagnostics, no stuck sensors on, and I've manually checked the diagnostic mode reads it (using cardboard strip to break light plane).
*I've also verified the red LED triggers on the opto boards. I've cleaned the sensors a few times with a Q-tip and rubbing alcohol.
*When its stuck in the loop there is no erroneous scoring, no other solenoids VUK, etc firing.
*Changing rescue modes stops the loop, but it will return once you loop back to it when its in the "stuck" state
I wasn't sure if this was a ROM issue, so I removed AROM2 (speech?) and the game still plays as it should. I get the regular callouts, at least what I think they should be. Follow up question I suppose, but what's the difference between AROM 1 and AROM 2? Don't get the annoying loop with AROM 2 out, and game seems to be playing well.
Thanks in advance, Cheers!
#2 2 years ago
Wondering if you did a full factory reset if that would clear the sound issue.?
#3 2 years ago
Thanks for the comment chad
I did try that initially (when I first got it), forgot to mention that!
#4 2 years ago
Pinwiki has some good info, but not too much regarding sound issues rom related. It's possible the rom could be corrupted. If you have an eraser you can carefully clean the legs.
https://pinwiki.com/wiki/index.php?title=Gottlieb_System_3
#5 2 years ago
That wiki is great! It’s how I originally found I was using the 110V jumper and not the 120V.
I’ll give the sound section a bit more of a read through as a noob I didn’t fully understand all of it, and I’ll give the rom legs a bit of a clean (have a bit of white oxidation)
Appreciate the help and feedback
#6 2 years ago
Just as a side note (maybe for those who may have the issue)....I did notice after watching a few recordings, the “loop” occurs when the mode starts but no “telephone ring” occurs.
Anytime the phone rings, audio callouts behavior is normal. Whenever it’s missing, or sometimes I’ve had a garbled noise, then I get in the audio loop. Definitely leaning towards replacing a rom 1/2.
Gave the AROMs legs a cleaning, and things look good (for now).
Can update the post later
#7 2 years ago
ONE more thing to add, again for those who may have had this.
In addition to missing the opening dialog (911 what’s your emergency, etc) in the start of the mode, I also noticed the baby doesn’t cry when you get the “extra bawl”. Definitely leading towards a ROM issue I think.
Good sequence example:
https://drive.google.com/file/d/13PRZz0RqYR1gaVKHibH7KIOgYA2wOn6c/view?usp=drivesdk
Bad sequence (missing opening):
https://drive.google.com/file/d/1h1FfZB_hIHHfjBf0jjQOfbYphfKg3c2P/view?usp=drivesdk
#8 2 years ago
So is this resolved now, or are you still having issues? I might be able to steer you in the right direction with some troubleshooting questions based on your responses.
#9 2 years ago
Thanks Ralph!
Still occurring unfortunately- It’s sporadic.
I ordered two new 6116 RAM chips for the main sound board, after some additional reading, I wonder there is a lane issue in RAM. A lot of new information to take in, and these Sys3 sound issues are definitely complicated!
After that, I was thinking of flashing new AROM 1/2.
Open to any other ideas!
#10 2 years ago
Quoted from DigitalJedi084:
Thanks Ralph!
Cool.. let's back up a little bit.. I suspect it's ram, as those fail pretty often, but let's eliminate the easy stuff...
Put the game in sound test and run through the sound tests several times, are any of the sounds missing? After that, reseat all ribbon cables several times.
Report back after doing both of those and we can go from there.
#11 2 years ago
Also, what is your 5 volt reporting at? You can grab the 5 volt reading from the upper connector on the small power supply board.
#12 2 years ago
Ah yes, thanks, probably should have posted that!
These are the measurements I took prior, is there anything else you’d recommend?
A5-P1
Pin 10 =11.89
Pin 5 = 12.05
A1-P1
Pin 1 =5.08
My +12 is a bit short, but I feel like 10% off would be in tolerances? I’ve seen the ranges listed for 5v, just never for 12v
#13 2 years ago
A5-P1
Pin 10 =11.89
Pin 5 = 12.05
A1-P1
Pin 1 =5.08
Those look fine....Let me know the results of the audio tests.... You should hear each individual sound as you go through them. For the sounds that are problematic (as you posted above)- run the audio test and press on the ribbon cables as you run the tests. I have seen cold solder joints and flaky ribbon cables cause these specific issues.
#14 2 years ago
Will do!
The stock diagnosis audio test (those tones) all work good.
Haven’t thought of trying to wiggle the ribbon cable. I’ve reseated it before and it seems like it worked temporarily, but could have been something unrelated.
I’ll report back soon
#15 2 years ago
I just tried wiggling the sound board to aux sound board ribbon cable, as well as some of the sound board input cables, but no luck.
I wiggled where the dialog should have been during the mode intros, and when it got stuck in the "please remain calm loop".
I did however clean a drop target switch, way easier to do than on my Lucky Hand! And I finished tossing in my comet LEDs while the playfield was up, so some minor victories tonight.
I snagged a spare sound board, and aux sound board on ebay for pretty cheap, and have some 6116s also coming. I figure a swap of sound boards, maybe I'll get lucky, and then that way we could at least isolate a board potentially. If anything the spare boards could give me some practice PCB soldering for the RAM =)
#16 2 years ago
I am still leaning towards the ram on this one. It's actually a pretty basic setup. Cpu triggers sounds to play via soundboard, and soundboard plays them. While it could be a corrupt rom, the fact that it is playing the proper sound and looping it leads me to the ram.
If you aren't confident in your soldering skills, feel free to send the board my way and I will be more than happy to throw some sockets in for you at no charge.
#17 2 years ago
I agree ralph- I’m leaning towards RAM too, and I appreciate the offer! I think I may give it a try, but will certainly let you know.
I also have a copy of Marcos test roms, I’ll run through that to definitely isolate it. Just waiting on fresh eproms and the flasher from Amazon.
Parts should be here in a week or so, I’ll update the thread once they’re in.
Side question, what’s the pitch-mating for these? I was on digi-key are there are a TON of 24pin sockets. I’m leanining towards 0.1” (2.54mm) as they seem to be most popular by a long shot.
Thanks again!
#18 2 years ago
Are you talking about for socketing ram? If so, send me your snail mail via PM... I will send you a bunch of SIP strips you can use. You will get various opinions about SIP strips vs. sockets, but I personally love SIPs as you can see traces when they are installed.
#19 2 years ago
Quoted from ralphwiggum:
Will do, thanks!
#20 2 years ago
So I was able to snag a used spare Aux sound board, and main sound board via ebay, Both pretty cheap. Originally was just planning on having as a backup or soldering testing/etc....but for shits and giggles I did toss the aux sound board in (transferred my AROM 1/2).
Game's been FLAWLESS. Got over a dozen plays this tonight, and all intro operator calls play, no looping "please remain calm", and the baby audio plays in the extra bawl mode.
I was convinced it was a main soundboard issue, but it seems that may have been isolated to the Aux board. I'll swap my old one in later to verify, I'm just enjoying the game a bit now =)
ralphwiggum maybe your initial thought of cold solder joints at the ribbon cable was correct? I can't think of any other physical components on the Aux that could cause that (maybe bad speech synth?).
Either way, she's good now! I'll update if the issue comes back, and when i have some time to swap boards again....for those other System 3 buddies who may have this same issue.
#21 2 years ago
Hey Guys-
Just reporting back, its been a few days. Have a solid 30+ games on it and she's playing wonderfully!
I swapped the original aux sound board back in, and it instantly was missing cues and looping audio.
So I think its case closed, bad sound aux board! Still a bit confused on what component would be contributing towards the loop, but I'm happy to be playing
Thank you for the help ralphwiggum chad and the rest of the pinside community
#22 2 years ago
I agree--whenever there's a strange playback issue with system 3 sound boards, first I usually verify the ROMs, and then generally go after the RAM. Most issues I've encountered have involved one or both of those things.
#23 2 years ago
Quoted from ForceFlow:
I agree as well, atleast from all the posts I’ve seen you and others troubleshoot!
Still waiting on some fresh eprom chips to flash the test roms on, but my reader/writer did come in via Amazon.
The only thing I can think of right now is that my original aux sound board may have a bad socket(s) on AROM1/2?
Or possibly the U1 MSM6295 4 channel mixer is shot. I think PBR has these foe $20, so may give that a whirl down the line
I did another quick swap and the issue 100% follows the original aux sound board. I’m gonna put new sockets in just to see.
While I’m happy things are working, I’d still like to understand what on the aux sound board may have been failing- if not for my own curiosity, but to possibly help others searching.
#24 2 years ago
Good to to hear you have wrapped up. !!
$ 1.00
Pinball Alley
$ 17.50
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/rescue-911-looping-audio and we tried optimising it for printing. Some page elements may have been deliberately hidden.
