So i went to move my gotleib rescue 911 into my basement and i took it all apart then reassembled...HOWEVER i reversed the P1 connector on the A3 driver board and the main power supply A2. The 20 pin ribbon calbe melted. I replaced the ribbon cable and the machine still does nothing. Its complete static and nothing boots. What do you think i should do. could this be the driver board (A3) , or the CPU board (A1) or is it something totally different. The dot matrix does not come on, the machine lights up but does nothing more.
See attached pic for the connectors i put in the wrong spot. These two circled in red were swapped and then the ribbon cable between A3 and A2 melted the 2nd from the bottom wire.
