(Topic ID: 197130)
Rescue 911 Beacon Issue
By MrBellMan
6 years ago
  • 7 posts
  • 4 Pinsiders participating
  • Latest reply 6 years ago by MrBellMan
#1 6 years ago
I'm working on a Gottlieb Rescue 911 and have an issue with the spinning beacon. If you look at the up close pic attached, you will see the gear attached to the end of the motor rod is worn down and no longer has traction. Even with a new rubber gasket installed, it will not spin the assembly. Is there a reliable fix for this without replacing the motor?
Thx,
Rob Bell
Robsgameroom.com
#2 6 years ago
Not that I'm aware of. It's not really a replaceable part, either. You could try scoring it with a dremmel tool if you have a pointy cone bit, but I probably wouldn't waste my time because of the worn area and since a new beacon isn't too expensive.
http://www.pinwiki.com/wiki/index.php?title=Gottlieb_System_3#Rescue_911
Look for a Peterson 771R or Wolo 3110-R. It's basically the same beacon, but with a car charger adapter instead of the mini fit jr connector.
#3 6 years ago
Right on! Thanks for that. I think for $20 it's a no brainer. Not sure if the other is even fixable!
#4 6 years ago
Wonder how many hours of use it took to wear down that much?
Kind of wish newer pins had coin counters not just in the menu. You can change boards and lose the amount of plays.
#5 6 years ago
Those knurled rollers wore down even when we were operating the games years ago.
#6 6 years ago
I think this one was really bad because it ran against the plastic for a long time once the rubber gasket had broken off, but I may be wrong.
#7 6 years ago
New beacon received today and except for the fact that I had to change the power connector, it's an EXACT replacement of the original!
Looks even better with a Red LED installed!
Thanks again for the info!
Rob Bell
Robsgameroom.com
$ 17.50
$ 1.00
Pinball Alley
This page was printed from https://pinside.com/pinball/forum/topic/rescue-911-beacon-issue and we tried optimising it for printing. Some page elements may have been deliberately hidden.
