Scan it in sections, stitch the images back together in photoshop, and then redraw it.
Easier said than done, but that's usually the basic prep work.
For printing, a roll of banner paper would probably work--then glue it to cardboard using an aerosol glue (spray lightly or the glue will seep through the paper--I would practice first). Or, ask a print shop to print it. Depending on the type of print shop, they may be able to print it on a sheet of stiff plastic. I'm not sure if print shops really do cardboard. Most are geared toward signage, so they should have stiff plastic.
Seems like a worthy project to tackle. It appears you could just scan a single section, draw that pattern, and repeat it to form the entire banner, then change flag colors, etc. Can't wait to see the result!
I'm going with ForceFlow 's approach. I scanned it, redrew the art in Inkscape, and got it printed on 3mil vinyl. It is adhesive-backed and I will attach it to illustration board I cut to size. Colours were obtained with my Nix scanner.
Once I got into it I found that the flags all had their own individual shape so I redrew them all separately.
May attach with double-sided tape or spray adhesive, I don't really want to staple it on like it was done originally.
Only cost $60 Canadian with tax to get it printed (3 copies of the art fit on the material, one extra just in case I mess something up).
Attached a PDF in case anyone else needs it.
If you don't mind spending a little cash. Go to a one day sign shop. They can print it on sign vinyl, which you can apply with slightly soapy water (1 drop per spray bottle) and a plastic squeegee directly to the cabinet. Only draw back long term, is the vinyl can tear. But paper tears worse.
Some sign shops can print directly to a sub striate like thin, .040 or .063 aluminum, which would be more durable on the game. But I would go with vinyl and keep the print file in case of a large tear or scrape down the road.
This page was printed from https://pinside.com/pinball/forum/topic/reproducing-vintage-side-art and we tried optimising it for printing. Some page elements may have been deliberately hidden.
