Quoted from Skypilot:So to start, what are good methods to scan? Can you use a copy machine,flat bed scanner? Again this is not my area of knowledge. Do you scan to a certain format?
The initial scan isn't super important, it's just the guide to put your tracing on top of. So jpg scan at 300dpi or better on a flatbed scanner is fine.
Here's a quick and dirty trace I did of one part of one of your forms. The edges of the boxes, etc can be cleaned up, but you get the idea - it looks much crisper. You have do decide if you want it to look right or look good, though, since this is obviously handwritten and you can make it look the same, but it will not look as good since handwritten has imperfections.
Form-remake-example.pdf
