Does anyone know what is the best way to restore your stainless steel side rails to get them to shine again or to get them back to the way they are new on the machine?
You want some sort of metal polish. Mag wheel polish from the auto parts store will do fine. I use Blue Magic. Put dab on a clean rag, rub on side rail. It's time consuming and smelly, but will clean up everything but ball trails on ramps (regraining fixes that).
Be careful what games you use it on. If it's an older game with fade or dings on the cabinet, making the side rails and lockdown bar minty may look out of place. Metal polish will make them look damb near new (except for the scratches, which will now be much more visible).
Very nice. You can also use the polish to clean plated metal parts above and below the playfield. Gottlieb used an awesome plating process back in the day. If the parts are just tarnished, polish will make them look spectacular.
Thanks phishrace there is alot of items that look as if they are brass or copper in the cabinet. That hint will come in handy.
I will start painting the cabinet tomarrow hope to have it done by the weekend, however I have sent my playfield to HSA pinball to repaint and clear coat it. Should look new when i am done. this is my first pinball machine and the bug has bitten me.
The nickel plated looking stuff is what will really pop after you polish it. The metal piece that goes over the shooter lane is a good place to start. Remove the parts before polishing so you can do both sides and don't get any polish on other parts.
Works on other metals too, but the chrome-ish looking stuff really stands out once polished. Be sure to post more pics when you get finished.
Quoted from jomama:Found the metal polish kit on ebay for 19.99. Thanks again for the advise.
Got a link to the auction?
Also, what is being used to polish? Just a normal drill, or are some of you lucky enough to have a adjustable speed bench grinder/buffer?
Quoted from dsuperbee:Got a link to the auction?
i used a normal power drill and work just fine.
No polish needed to restore stock appearance. Just use painters tape on the cab and glass for protection, then sandpaper to desired grain. I took my TAF from crappy to gleaming in less than an hour of elbow grease and a few grades of sandpaper. Actually I used the spongy sanding blocks, kept damp (but not wet) to cut down on dust. Works wonders.
Good luck!
Brian
Not sure. It's not printed on the blocks, but I'll venture to say 200 to remove scratches, and 400/800 to target finish.
I just went to ebay and looked up stainless polishing kit and it came up with several kits, most were the same company. I went with ENKAY Stainless Steel Polishing Kit #143 it veried from 24.99 to 17.99 just had to look trhough them and they will work with a drill also.
Quoted from pinster68:Not sure. It's not printed on the blocks, but I'll venture to say 200 to remove scratches, and 400/800 to target finish.
Do you know what color they were? I think the color may be code for the grit on those things
Quoted from Old_Hutch:Do you know what color they were? I think the color may be code for the grit on those things
Sort of dull grey. I don't think they were color coded like Scotch-brite pads - which incidentally might work quite well too.
It is almost a white gray in color and it has 3000 grit on the block. It is a 3m sanding pad I got at Auto Zone.
The Pin Family is that buffing motor the one from Harbor Frieght. I am looking at one on their site.
Quoted from jomama:The Pin Family is that buffing motor the one from Harbor Frieght. I am looking at one on their site.
It is. It does the job but I think a better one would have more torque. It needs more torque. For occasional buffing its fine. If you plan on polishing all the metal for more than 2-3 pins a year id get a better one.
Jomama. I have used Scotchbrite pads (green) with pretty good results, hand polishing in the direction of the grain. It doesn't produce a mirror finish but instead puts a "grained" look that I think resembles the original look. I saw a Delorean owner polishing his car recently at a show using the maroon Scotchbrite pads. (stainless steel body panels) Straight motions in the direction of the grain. The maroon is slightly finer. Wally
This page was printed from https://pinside.com/pinball/forum/topic/repolish-stainless-steel-side-rails and we tried optimising it for printing. Some page elements may have been deliberately hidden.
